So my old dremel tool packed it in the other day. It was probably a quarter century old, more maybe. Planned on ordering a new one but as it turns out I have an immediate need. I stopped by a Harbor Freight and grabbed a Bauer. You know,to tide me over. Well, it does nothing! Turns on and as soon as you try to do anything it stops! Turns itself off ,like an overload switch. So it’s going back. A Home Depot, only a little further away has an assortment. I want a corded version and if I were to purchase a battery powered one I’d probably consider the Milwaukee because I have lots of M12 batteries, well 6 anyway. So what’s the best Dremel these days? Lots of different versions. I have a bunch of accessories so something that will let me use my old stuff, lots of power, variable speed.
Can't speak to any of the others, but my corded dremel 3000 serves me well. Granted if I wanted to do any work with the speed lower than about the 3 or 4 setting I have that quit under any load issue you had. Fine for me as I've never cared to go less than 8. Maybe I got a lemon, maybe it's a common issue I don't know. I've never cared enough to talk to customer service about it.
I was about to have my Olde beast of a dremel rehabbed when I came across a 4300 kit at an estate sale for $40. The thing does all I ask of it. I like the way you can swap nose attachments. I've adapted and re-adapted a couple to other uses. I run it just below the highest speed to reduce vibration. Never really tried low speed. I have a Foredom flex shaft for heavier work and powercarving so the Dremel never really works up a heavy sweat.
My only experience with them is a corded Dremel long ago that didn't hold up very well and a copy made by (for) Black & Decker that has held up well although I did replace the front bearing once.
I bought a battery powered Dremel for my son years ago and it was not worth much; no power.
I have no first hand experience, but the Milwaukee 12v looks attractive since you already have batteries. 12v appears to be more power than most other battery powered "dremels".
My biggest complaint about "dremels' is the lack of power and the ability to do any "real" work. However, the 1//4" electric die grinders are just too big. I've often wished that there was something in between. if your experience is the same, you might look at the Milwaukee 1/4" cordless die grinder. It appears to be only slightly larger and looks more useful to me.
I have the Milwaukee M12 version. I mostly use it with small abrasive cutoff wheels. I like cordless over corded, and I already had the batteries.
