Can somebody give me a quick course on dressing a grinding wheel. Bought the Norton carbide dressing tool and need a few tips. Is one of the goals to get the wheel square across the entire surface or thats not critical?
That's one important goal. Another goal is to "freshen" the surface. At least that's how I see it.
I always use the Veritas jig to hold the dressing tool. I also always use the diamond dressing tool.
Using the jig makes sense to me, but do guys do it freehand with good results? Seemed pretty tough to me to achieve a true surface across 1 in. freehand.
Edited 11/1/2004 8:51 pm ET by CIRCLEKID
I wouldn't do it freehand myself. I don't know if others do, although I expect they do. I mean, the point is to get the face of the wheel parallel to the tool rest all the way across, so why guess?
Yes, you want the grinding wheel to be flat across its surface. And you want the wheel surface to be parallel with the tool rest (you can adjust the tool rest to accomplish this part, but I apply my dressing tool to the wheel based on the tool rest.
That way you can sharpen a chisel (for example) using the tool rest at the appropriate angle (bevel) and "attack" (skew) using teh tool rest as your reference. I hope this makes sense...
It's a great question!
So when you apply the dressing tool based on some reference point on the tool rest. Do you move it slow and methodical across the surface or do you use kind of quick sweeping strokes the entire surface.
"Do you move it slow and methodical across the surface or do you use kind of quick sweeping strokes the entire surface."
I go slow and methodical, just as if Iwere turning a straight edge on a turned piece on a lathe. It's a practice thing...whatever it takes to create a flat surface on the wheel.
Going slow will make the wheel "cut harder". Equivalent to using a harder finer wheel.
Going faster will make a wheel "cut softer". Equivalent to using a softer coarser wheel.
Hi CIRCLEKID ,
I would tend to agree with Mark , the dressing freshens the surface of the stone . Also you can use the stone dresser to shape the stone to aid in tool and cutter grinding and shaping of different profiles .By taking light passes across the stone you can quickly remove the worn portion of the stone .
dusty
