It looks like it has been about 11 years since anyone posted on the subject of using dricore to put over concrete garage floor for workshop purposes. My question is whether anyone has experience with leaving the osb-type surface unfinished and whether the surface stands up well to machines on wheels and general use.
I know you wanted comments from experience but I have installed in basement remodels but not in shops like you are talking. Since you are referring to a garage shop I am assuming you are using mostly hobbyist level tools which are much lighter than industrial or pro level tools, I would think you would be fine, but if it were me and would definitely apply some type of finish just for ease of vacuuming and cleaning. It would be a simple matter to get a large pole roller and some floor poly and put 2 coats on top before the tools are moved in.
I have used a sheet of OSB under my work bench for a few years, because I was tired of repairing chips in tools the fell off the workbench on my back porch concrete floor. It still looks like it did when I first started using it.
I put DriCore in my shop in 2012. I did put a general purpose water based poly floor finish on it with some anti slip additive in the second coat. I have been very happy with it and it has held up well. Most of my big tools are stationary but my assembly bench and a few tool cabinets are on wheels. I have not had any wear issues. I have a 700 pound lathe. There is no sign of denting under the legs. I think it is a great choice for the work shop. Easy on the legs and even kinder to the inevitable tool drop. My shop is 24x30 dedicated as a wood shop. I am just a hobbyist but am in the shop about 5 days per week.
Thanks all for comments. The R+ stuff is rated for 3000 lbs per inch and a key reason for me is to add some warmth, the rest of the garage is insulated. I like the idea of poly and then anti slip. There’s a couple spots where the tongue and groove aren’t quite seamless so a coating would take care of any potential issues with spilled coffee or other things working their way into cracks.
