How many speeds does a woodworking drill press need? I’m looking for a new or used drill press, but what about its speeds: Do I need 12 speeds or are 6 speeds good enough. Seems that many older Rockwell/Delta drill presses didn’t have that many speeds.
Martin
Metal workers need a variety of speeds on their drill presses. Most woodworkers only need two or three, I use one 90% of the time.
myhomereno,
I only change speeds for Fostner bits. Perhaps they would be a good reference for you..ie. how many speeds, and does the speed match the bit requirement.
Here's a handy chart. Seems like you could probably get by with 6. Generally, I also change speeds mostly for Fortsner drilling.
Thanks for posting the chart; handy!
You're welcome. I should use it more often -- tend to get lazy about moving that belt around. However, the drill press is now in a new, easier-to-access location, so am going to try and be a little more selective about speeds. forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
If you are looking at new drill presses you could consider a variable speed machine, in which case the whole issue of number of speeds just goes away. And to echo a previous comment, woodworking doesn't require more than 3-4, but it is important to get one that has a sufficient low speed for forstner bits.
Finally I made up my mind and went to the local Tool store (Summit Tools) and looked at a 16 1/2" Delta 17965 drill press. It was on sale for $450 CAN. While I looked around I saw a Delta variable speed 17990X, one of the X5 modells, for $730 CAN. The sales guy told me about a Delta rebate program (Beltsander, Router or $100CAN cash back) and I was convinced to buy this drill press.
I picked it up last night and this weekend is assembly time. Hopefully I get the time today to go out and pick up a mobil base for it. I saw in the local paper a used HTC base for sale, maybe I will have a look at it.
