I recently purchased the Powermatic PM2800B drill press as an upgrade for my shop. My shop is small and in order to maximize the space all my tools are on some form of mobile base. My previous drill press was smaller and weighed considerably less than the Powermatic so using small mobile base was an easy task. But given the size and weight of the Powermatic, I was hoping someone here has some experience with using this drill press on a mobile base. Those of you that have a similar set-up, what have you used that worked well? My Initial thoughts are to build some form of a mobile base with all movable casters and then some form of a cabinet, also on casters, that will nest over the drill press base to store all of my drilling accessories. With that idea in mind, I’m unsure on how to dimension the base to maximize stability while still being easy to move around the shop. Thanks in advance for all your help.
I got a Nova DVR drill press last year, and got a Bora mobile base for it. I looked around a lot, and it was the best I could find. This is the one where all 4 wheels swivel. I can maneuver it easily around my tiny shop while not in use. They have the same base but with only 2 swiveling wheels, but it takes more back and forth to move it around.
My drill press isn’t as nice and weighs probably 100 lbs less (might be the one you are upgrading from—it’s a Porter Cable), but my setup works well for me and *seems* stable.
Base is two pieces 3/4” plywood (glued), fasteners are big lag bolts. It’s sized based on what I had for scrap and what seemed right. I don’t know if it’s “appropriate”.
The storage cart has been super useful. It’s the same height as table saw and serves as outfeed table. It’s also my sharpening station (water stones and honing guide etc in top drawer) and I’ve used it as clamping station/bench when dovetailing large panels.
It was fun to build :)
The video at https://youtu.be/vk0RObiBCPY shows construction of what looks to be a pretty robust mobile base, using Bora Portamate PM-1100 casters, for a Delta 18-900L, which looks to be within ~10 lbs. or so of your drill.
Grizzly makes a set of very nice mobile bases called “bear crawl”. Others make them as well. They have hard urethane treaded metal wheels that roll very well over concrete. You can get them is several sizes. This one on my Nova drill press is one of the larger ones.
Everything in my shop is on wheels. I find there is a certain amount of slop in casters even when they are locked. Movement and vibration are the enemy. I would suggest, especially with a potentially top heavy machine, that you get or make a base with retractable wheels so that when in use the drill press is sitting directly on the floor and more stable. I personally hate bases that have two fixed wheels and one or two wheels that rotate. Having to back up and push and maybe repeat that several times to dosey dough several very heavy machines around each other when I want to change up my set up is really annoying and tough on the back. With retractable wheels they can all rotate and you can push them in any direction you want. I haven't gotten all my stuff set up like that yet but I'm working on it.
I agree with having two fixed casters, too much back and forth to get things where I need them. I was thinking of using some casters like the one in the attached picture. I used them on my lathe stand and when I lower the foot pads, they are very solid, even when turning larger pieces that may be out of round when starting.
Can you provide a source for these casters with foot pads?
I got my from Amazon, the link is included below. Woodcraft usually carries this style as well.
https://www.amazon.com/dp/B0713S3HZ7/ref=sspa_dk_detail_0?psc=1&pd_rd_i=B0713S3HZ7&pd_rd_w=8LruN&pf_rd_p=887084a2-5c34-4113-a4f8-b7947847c308&pd_rd_wg=pR4Kn&pf_rd_r=5V8V66BC64N6G2DZSXFS&pd_rd_r=32545713-22c3-4c8f-9368-f20ec7d6595a&smid=ACW735TCSNMVE&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExWVpFVUc0VjdVNlhZJmVuY3J5cHRlZElkPUEwNTg1MjE2MjZKTktTMkpNUFZFRiZlbmNyeXB0ZWRBZElkPUEwMTMwODUwMjRWSjc3Q0tBQlZPRyZ3aWRnZXROYW1lPXNwX2RldGFpbCZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
Best base hands down is the sawstop industrial mobile base. Straight up and down on hydraulics, 360 spinner, and the machine lands on the floor. Pricey, but you get what you pay for.
I have that base on my Sawstop PCS and it makes moving the saw around effortless. Have you adapted that base for use with other tools?
I had one cut down and re-welded to fit my 12" jointer/ planer. Makes the changeover really simple. I have to spin the machine to keep the feed direction towards the dost collector and it could not be easier.
Which jointer/planner do you have and how do you like it compared to separate machines? I've been looking at some of the jointer/planner combos trying to decide which one I like best. Right now I'm leaning towards the CWI Scorpion.
My choice also in 2018.
I bought the PowerMatic table top mortiser a while back and went through the same thing trying to sort out what mobile base to put it on. I ended up purchasing DeWalt's kit that you would use for their table top planer. I've been happy with that mobile base. That would be my reccomendaiton.
