drill press speed for soft wood such as yellow cedar
what speed should be used drilling into soft woods. such wood as yellow cedar ,and sugar pine
Depends on the bit type and diameter. Do a web search for "drill press speed chart" and you'll find charts which will give you the speeds for various bit types and bit diameters depending on the material being drilled. I have one of the charts laminated and attached to my drill press for quick reference.
I pretty much leave my drill press set to a high rpm for wood.
IMO high rpm and a slow entry are best for soft woods.
Generally . . . smaller bits = higher speed, for that figure a softer material = higher speed. As eieio1 states, bit type, geometry and material all play a role. Here's a chart I keep stuck to a cabinet near the DP and one from Wood Mag.
