Drill Press Table – Help needed
I’m building an extended table for my drill press and I had an idea I’d like to implement but I’m not sure how to go about it.
The table itself has track for a fence. I’m good there. And the underlying drill press table will tilt left and right, but not along the forward / backward axis. I’d like to make my table do that but I’m not sure how to go about this.
I have some piano hinge laying around, but the table will be fairly heavy – how can I design this thing so that I can tilt it at any reasonable angle (say up to 45 degrees) and then secure it for working?
I saw this: http://www.woodmagazine.com/wood/story.jhtml?storyid=/templatedata/wood/story/data/397.xml
but I’m not sure that this will work for… those friction lid supports dont strike me as being particularly strong…
your thoughts?
Why not tilt the entire table top on a piano hinge running across the back of it and suppoort the front edge with a prop rod?
Attach swivel blocks to the outside of the table base (see ShopNotes #57 for the basic table base design I have in mind ... basically a box beneath a platform) and raise the top on all-thread passing through T-nuts in the swivel blocks.
Now that you've got the creative juices flowing, I think I'll go back and modify the DP table I completed only last night! ;-)
