I am building a work table and just bought a 30 inch by 72 inch maple counter top, 1 3/4 inch thick, for the work surface.
I want to drill a series of 3/4 inch dog holes in the maple counter top.
Obviously, I cannot fit the counter top in my drill press. Any sugestions on how I can drill holes that will be perpendicular to the work surface and also aligned with each other.
I tried using on a scrap piece of lumber a “portable drill press,” the type where a hand drill fits onto a slide supported on two spindles attached to a base, but there was too much vibration and the drill bit drifted too much – the resulting hole was not perpendicular to the work surface.
All thoughts?
Burt
I recently asked the same question, here is the thread. I ended up using a jig and a forstner bit with extended shank, both purchased from Rockler.
http://forums.taunton.com/fw-knots/messages?msg=34614.1
This is what I used with much success, my benchtop was 3" thick maple...
http://www.rockler.com/product.cfm?page=1633&filter=forstner
Edited 3/11/2007 8:01 pm by jeff100
Jeff,
Thanks....read your response, as well as those who responded to your question...nothing like information overload :-) Taken together, I have a much idea how to drill the holes.
Burt
I drilled all the holes in a work table top with the same set-up you have. The trick to keeping the forstner bit from wandering is to use an awl to make a small starter hole.
John Wooden 1910-
Good point, I forgot to mention that. I took a 16 penny nail and ground the end on my bench grinder to a nice round point and 'center punched' each hole location to give the forstner bit center point a place to register. You are right, it prevents any wandering on startup, and once the hole is established, the jig and the established hole prevents the forstner bit from diverging from a straight hole. Since my benchtop was approx 3" thick, I had to remove the jig and drill the last approx 1/4" free hand, being careful to keep the drill perpendicular to the benchtop. I was very surprised at the minimal to no tearout on breakthrough with the Rockler carbide forstner bit, although I was careful to reduce my feedrate when I was close to breakout. I probably could completely eliminate any tearout by using some tape (yes, I know adding material is what's normally done), but the tearout is so minimal, if any, I don't worry about it. I needed thru holes in most places due to my use of old fashioned hold downs, which I find truly amazing in how well those work...Jeff
Sears sells a jig for that purpose. I used it in my bench, and no problem ( 40 holes)
If anyone in the seattle area needs help drilling the dog holes in thier bench I have aMag drill/press that works very well for this. You just clamp a small metal plate that is just bigger than the footprint of the mag drill to the benchtop(10" x 10"or larger) & you can shim it for your req. angle then set the mag drill on the plate - align to the req. hole location - turn on the magnet - turn on the drill & drill your hole. I am willing to help or loan this to anyone in the seattle area for this use if you would like to use this method.
