Reading the recent issue of FWW, I came across the “wipe on” finish article that has been discussed on this forum in another thread. Chris Minick measured the viscosity (“thickness”) of the liquid finishes using a drip cup. I’ve seen these in other articles and have always wanted to get one so that I could better mix my own finishes- but I’ve never seen one for sale, that I can remember.
Does anyone know of a source for drip cups?
Glaucon
If you don’t think too good, then don’t think too much…
Try some where like VWR.com or any chemical/lab outlet.
"...we mutually pledge to each other our Lives, our Fortunes and our sacred Honor."
"Kill'em all and let Allah sort them out."
Try to do a google on "zahn cup".
Here is a link explaining a little more about viscosity cups and their use.http://www.furniturefinishwizard.com/viscosityandwetmils.htm
Harbor Freight also sells them for $6.99
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=47399
They are also called viscosity cups. You can do a google search for them to buy elsewhere if you do not like HF.
Thnaks. I wonder how HF can screw up a metal cup... I'll give 'em a try.
Glaucon
"I wonder how HF can screw up a metal cup... " ROFL! Let us know, will ya?forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
drip cups are usually available thru quality auto paint stores.....
Homestead Finishing sells them.
Glaucon, Many years ago as a teenager, I had a job in a disc recording blank manufacturer. We manufactured lacquer coated cardboard recording discs to send to our servicemen in Europe and the Pacific (1944)
When preparing the lacquer for the right consistency for the dipping process,we had to consider the room temperature/humidity and viscosity of the huge tankful of the dark blue lacquer.
For the viscosity, we timed the flow of a funnel filled to the top with lacquer while holding the funnel level and stopping the flow with our finger tip. The other hand held a stopwatch.
At the right moment we would simultaneously release the finger and clickstart the stopwatch.
At first sight of daylight showing through the bottom of the funnel, we clickstopped the watch.
To insure accuracy, we had to do that procedure at least three times.
By adding butyl acetate or zylol thinner, we would adjust the viscosity to the needed thickness.
Perhaps some older guys out there remember receiving these 5 inch
card board records overseas?
I made thousands and thousands of them; ( also 16 inch aluminum transcribing discs) for the recording industry.
Steinmetz.
Edited 6/23/2005 5:37 pm ET by steinmetz
