I have a 37-220 Rockwell Delta 6in. jointer.The tables are drooping at the ends. I hope I did not screw things up I tightened up the Gibs on both the tables, the front tabel I tightened the lower screws more than the top screws.
Can someone tell me how you rasie the ends of the tables? Shims?
Call Delta technical help. We have the 8" professional jointer in our shop and by tightening up the screws in the proper sequence you should be able to straighten it out. Obviously the screws on the out feed table can be a bit tighter because it gets moved less.
