At a recent woodworking show I saw 2 vendors selling a drum sander that you operated like a jointer. Instead of a 3 knife cutterhead, there was a sanding drum. Are these any good? Do you have a link?
Thank you,
Don
Thank you,
Don
If it's what I'm thinking of it's not a jointer but a low budget drum sander being marketed as a kit. I would not imagine having a sanding drum as a jointer head would be efficient or worth the trouble. It would be very slow and would change in diameter in relation to the height of the outfeed table.
Hi Don-----you are not completely off base. I live in the center of a lot of furniture manufacturers and they do use "abrasive" planers especially on glued up stock. I guess that was better to remove the glue than chipping up hard knives of tool steel. I have not seen any such planers on the artisan level though.
Cheers, Jerry
Check out sandflee.
I have no idea if it is good or not.
http://www.woodpeck.com/sandflee.html
Don,
A drum sander removes wood tissue more-or-less uniformly across the width of a board like a jointer or thickness planer. However, you can hog off much more with a jointer or planer in a single pass than you can using a drum sander of the kind typically found in a home workshop.
I typically remove about 1/200th of an inch per pass with a finishing sander or drum sander, but I can remove far more with a planer or jointer. On the other hand, a sander won't cause the kind of tearout you'll get when using a planer or jointer on highly figured wood.
When I'm squaring rough-sawn stock, I use a jointer, planer, and table saw. I wouldn't consider trying to use a sander to square rough stock.
By the same token, I use a finishing sander to remove very small quantities from the face of a panel until the surface is uniformly flat and smooth - a task that's not well suited to my planer.
Bottom line - IMHO, these tools have different purposes, despite their similar functions.
-Jazzdogg-
Like the others said drum sanders are good for very light passes and not so good for dimensioning. I have run a lot of bandsawn plys for bent laminations through a buddy's Performax ShopPro 25. It's excellent for removing the band saw marks. It's also excellent for taking out planer marks and reducing the amount of time spent with an R/O after traditional jointing and planing. Burning is a real problem with drum sanders, especially with oily species. QSWO and Hondo will tolerate no more than a 1/6 of a turn for successive passes. Purple Heart just wanted to burn no matter what and when you burn it you loose a 12 - 15' roll of abrasive.
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
Don,
Some drum sanders can be used in the same manner as a thickness planer. I have a dual head 25" drum sander with 36 grit paper that can remove as much as 1/8" in a single pass in softer woods but it is no real substitute for a planer/jointer. I use the drum sander primarily for finish work.
One drawback of a belt or drum sander at your primary thickness tool is that they will not flatten your stock as will a jointer. A recent issue of FWW, at least I think it was FWW, had plans for a sled that can be used with a planer to flatten boards.
Doug
Doug,
What brand of machine do you have? How much was it? And how much power does it have? Sorry if that is rude. I am looking at the Grizzly dual drum sanders. For less than $2000 they seem like good machines but I am fearfull of getting a "cheep" machine. I am also lookin at the Powermatic, but I'd have to find a used one. And that dosen't seem to be very easy.
Mikeplease excuse my spelling.
I have the PerforMax 25 Dual Head. I bought it used for $750 and put another $100 into it to replace motor pulley, belt and assorted small parts. I think the machine new runs around 3-4K new, but don't quote me on the price. I got really good deal but it takes up a lot of room, the roll paper is not cheap but when you need it, it an invaluable time-saver. This is not a purchase I would recommend if you do not have your basic equipment already in place, including hand tools, and you are not planning to be more than a serious hobbyist. I purchased this with retirement and furniture building in mind, not to support my hobby.
PS: This is a true 5HP motor drawing some serious amps.
Doug
Sounds like the Sand-Flee is what you saw. It's awfully expensive ($595) and looks to me like it's mostly intended for smaller projects. You can get a good jointer for that price.
