I’m looking for a thickness sander and have no experience with these
tools.
As with any tool and in fact, just about anything you buy, I’m guessing
there’s an asymptote where the price goes non-linear and the quality/capacity
increases only marginally.
Can anyone provide the following recommendations:
1) How big a unit should I buy ?
I have plenty of power available.
2) What manufacturer builds high quality, safe, easy to use units.
3) How often and how time consuming is it to change the drum (or paper on the
drum) ?
4) At what price point to get into very nice units (as in you’re not longing for more)
Thanks!
JR
JR,
Can't answer your question since you've provided no information about how you intend to use the machine. What I can give you is my experience with a 5hp 25" dual-drum sander. It is a love-hate relationship:
Okay, those are the downside points. On the upside:
Mine is a production model and I got a good deal on it. Were I doing it again, I would not buy a stationary sander unless the majority of my work involved a lot of solid wood slab-sided cabinetry and/or frame and panel doors and I was doing it for a living. In retrospect I would have been better off putting the money into a 4 x 24 belt sander with a frame and L-N hand planes. For the occasional need, I would use a local cabinet shop and run it through their wide-belt machine.
Bottom line, it still gets back to the problem you are trying to address with this piece of equipment. If you need the capability of a stationary sander, then I think you would be better served with a wide-belt sander over drum sanders. If you decide on a drum sander, I would one that does not cushion the roll paper since that will tend to distort the edges of the material and not always flatten hard, high spots on boards. This includes the H & L backed systems.
For what it is worth, this is my story and I'm sticking to it :)
Doug
Doug, thanks for the thorough reply !I do want to get a stationary thickness sander. Of most importance is to be able to dial in
a thickness on a very well calibrated tool and have it produce stock with according precision.A millimeter is about as course a graduation as I would want to deal with. Ideally, within
a few tenths of a millimeter, but I think the ultimate target of 1/2 a millimeter would work
great.One thing that I have a hard time with is buying tools that have only English units. They
are much more difficult to work with mathematically.
Unless you you go on the upper-end of production machines, the measurements are trial and error. The measurements change based on the paper grit. I use a scrap the same dimension of my finished stock and try it until I get what I need. To much and you can burn the material, particularly the high sugar woods such as maple and cherry. I would not trust a scale on these machine except to get me in hand grenade proximity to my target thickness.
Doug
Doug, you're information was confirmed with the several phone calls
I had made earlier today. I was hoping to dial in a thickness with high
precision. The majority of machines capable of this require three phase
and the cheapest I found, the General International 15" open ended
(which requires a 75 PSI airline feed to operate) was $6000.The guys I spoke to at Performax were very little help. I was duly
unimpressed with their understanding of their own machine and
willingness to learn more about it to provide me the answers I was
looking for.
If you really want to know about PerforMax products, talk to Dave in Technical Services. He has worked with these machines since forever and is a wealth of information as well as being a nice guy: 800 274.6846 ext 1322.
