Looking for information on drum sander opinions and sources.
Performax makes an excellent selection of drum sanders. depending on what your need is and how much you want to spend. Just a suggestion buy the biggest sander you can afford, because once you start you will only grow to do larger work , and than you'll be stuck with a machine that is too small for you. Good luck
http://www.wmhtoolgroup.com/Performax/Tools/2244Plus.html
