I am a beginner and am looking to buy maple drum shells and finish one drum at a time until I complete a drum set. I am looking for some advise on finishing techniques that I can do at home that provide great results. I was originally considering using wipe on poly but after reading several posts…it seems that people are advising against it. Ideally I am looking for a satin or gloss finish that provides some depth, durability that doesn’t yellow.
I'd recommend wipe-on poly for this application. It's pretty easy to apply and wears quite well.
Thanks for the suggestion. How many coats? How long between coats? Should I sand between coats?
Thanks for sharing
A few years ago I built a stave-construction bass drum out of maple. I didn't want any yellowing or amber cast to the color so I chose to use water-based poly, specifically General Finishes High Performance Top Coat. I used an HVLP sprayer with 3 or 4 coats and the finish came out very well. If you don't have a sprayer, you can use foam pad applicators. Make sure to experiment with a sample first!
Poly will be great for protection. BUT poly is know to stiffen the wood keeping it from vibrating how it natually wants to, which in turn will kill the tone of the instrument. I can't even begin to count how many chinese made instruments i've brought back to life by simply and carfully sanding off the poly and refinishing with a laquer or oil finish and then spraying 3 - 4 clearcoats to seal and protect. With maple especially, I would recommend just doing a straight laquer finish it can be sprayed or wiped (i believe, ive only ever sprayed laquer) 4-7 coats depending on how much protection you want
