Greetings,
I built a work tabletop with laminate on MDB, with maple edge banding. I was careless removing the carpenter’s glue squeeze-out; I have a few areas on the laminate surface that have thin areas of dried glue. Not ‘bubbles’ you can knock off with a sharp tap, I didn’t fully remove the glue when wiping the area, so it’s spread out and quite thin. I need suggestions for removal.
I’ve tried soaking washclothes in hot water and placing them on the dried glue, but no go. I’ve used a fresh single edge razor blade to scrape, but that’s risky to the surface of the laminate.
Got any ideas for a solvent that’ll attack the glue but not the laminate?
John
John... try a rag that is wet with WHITE VINEGAR. Let it sit for a while and it should come off. Use a single edge razor like a cabinet scraper if needed. Yes, I know we're talking about a workbench, but it will get dinged up after a while. Just like a car, you baby it untill it gets that first major ding from someone in the parking lot, then you don't care about dent 2,3, and 4.
SawdustSteve
White vinegar, huh???
I just learned something new!! :~)
Vinegar as already mentioned or photographic Acetic Acid which is a lot more concentrated than vingar .With vinegar leave it soaking overnight.It does not dissolve pva but softens it
Thanks to all who replied; I'll give all the suggestions a try and report on the one that is most effective in my case.
I got the vinigar recomendation from the techs at Titebond but being the impatient type went to acetic acid Photo strength
Geez...I woulda just touched up everywhere else with MORE GLUE..<G>
Johnny,
Great advice from all - when dealing sith solvents, just make sure that it's a white rag to avoid re-colouring your job. Especially when there's prolonged contact with the job involved.
First year apprentice mistake - I think we all make it.
eddie
A little acetone or lacquer thinner on a rag will take it right off. I just tested it to be sure.
Even scrubbing it with a cloth wet with hot water will do the job. At least it has for me in the past.
White vinegar should, too. Again, don't soak it, scrub it with a wet cloth. Less chance of damage.
Michael R
