I recently had a 30″ beech milled into quartersawn billets, 16/4 square and 50″ long (about 100 of them) for my planemaking workshops. These have been sealed, stickered and stacked outside covered. So far they have lost about 35% of their initial weight (I stacked the wood so that I could withdraw one billet from a central area for periodic weighing). Rather than wait ~4 years for the stuff to dry, I want to push it along somehow. Local kilns are not interested in working with wood this thick, or in small amounts. Any suggestions?
If you're going to cut them down to "plane-size" you could dry them in a microwave.
David Ring
Bill,
A year or two ago there was an article in one of the magazines FWW or maybe Woodwork for building a smallish dry kiln. plywood box with a light bulb inside, and maybe a small fan. The guy was using it to dry chair parts. I can't find the thing now.
Bill I’ve had some good luck using a small heater (electric) and dehumidifier couplee with a small box fan with a rheostat . I created a small frame to cover the pile and enclosed area with a heavy mil plastic. I then added 2” foam board and sealed the edges and corners with duct tape. I went from wet lumber to 12% on 6/4 stuff in about thirty days using beech
