I’m in the middle of making 6 greenwood chairs using cleft oak shaved to shape along the grain with a drawknife and spokeshave, etc..
The rungs are made first, with round tennons turned on each end. When dry, they are inserted into round tennons made in only partially dried legs. Leg shrinkage subsequently exerts a vice-like grip on the tennons so the need for glue is obviated.
The first chairs I made were in ash, over 1 week. My tutor dried the ash rungs rapidly in his oven, so the project could be finished in 1 week. Ash is OK with this treatment but the oak I am using now is not. It would split reet quick if I tried to oven it, or even left it in the sun.
I don’t want to have to wait weeks for the oak rungs to dry out slowly, so I considered helping the process along using steam.
The chair legs and slats are steamed to bend them. Paradoxically, when they emerge from the steamer and have cooled, they have reduced in moisture content from their 40%-ish at green to around 20%. Strange. But true.
I hope to steam dry the rungs and avoid splitting. Steaming the back slats prior to bending them has certainly not caused them to split.
I’ve searched the Web a bit but can’t readily find out why steamed wood loses rather than gains moisture content. It seems counter intuitive.
When oak (and ash) is steamed, there is a delicious smell of Xmas pud from the steamer. Perhaps the steam is leaching out the sugars in the green wood and, by doing so, immediately reducing its water-retaining ability? In a former life, I was a bit of a racing cyclist, and dietry wisdom advised one to avoid energy intake via sugary choc bars, as sugar apparently attracts 2 1/2 X its own weight in water – sucked out of the needy cyclists’ bloodstream straight into his digestive system. (But I digress).
Anyone have wisdom and knowledge on this phenomenon? (Drying via steam, I mean, not cyclists diet). Can one steam wood to as low as 10% moisture content, or is this not physically possible?
I'm a boatbuilder, and do a fair bit of steam bending, mostly of oak. Steaming green oak helps to dry it out with heat, and the humidity seems to help keep it from checking, as you know oak is prone to doing. You certainly won't dry it out though. Thoroughly air dried oak swell when you steam it, making for much frustration when fitting planking. Pieces the size of what you're working in, after being steamed for awhile, should air dry within a week or so. If you have trouble with checking happening within a short time after steaming, try putting linseed oil on the wood before it goes in the steam box.
Thanks for the info - no checking so far with a little steam-drying experiment I ran; but the linseed oil tip is worth knowing.
The little experiment went like this:
Take 10 newly made chair rungs, made with the oak straight from a freshly-cut log (ie as moist as it gets) and accurately weight them - exactly 3lbs (48 ozs).
Steam them for 3/4 hour (with some chair slats that need steaming to bend anyway).
Let the steamed rungs dry off for an hour outside the steamer (but in a cold, dark shed, so no other drying effect than that from the steaming takes place).
Weight the 10 steamed rungs again - exactly 2lbs 13.25 ozs.
Weight loss via steaming = 2.75 ozs or 5.7%.
Now all I have to do is work out what that equates to in percentage moisture reduction within the oak. My head already hurts.
