Hello: I’ve been looking for a good dovetail saw and found so many different specs on them that I’m kinda lost. I have been practicing with c.c. and rip tenon saws that I already have with mixed results, I guess they are too large to make such small cuts accurately. I want a western style one and have looked at Adria, L.N., Pax, Lynx. Closed handle or “gents” style. 15 tpi or 20+tpi. ???? I assume the smaller the kerf the better and have seen some set on one side only. Also what can a coping saw be used for in cutting d.t’s? Can’t buy em all, so what do other Knotheads use?
Thanks, KDM
The Bill of Rights
December 15 1791
NRA Endowment Member
LEAA Life Member
CRPA Member
I think there is another post in here like this..
a good dovetail saw ..
I think it really boils down to ANY saw you have you can cut a STRAIGHT line with...
Ken, I use a Japanese saw that cuts on the pull stroke for dovetailing. Cutting on the pull stroke gives me more control than a western style saw which cuts on the push stroke. The saw has 32 tpi and has a kerf of 0.011" (thickness of about 3-4 sheets of paper). The particular saw I use is from http://www.japanwoodworker.com and comes in 2 sizes. The part numbers are 18.210.0 and 18.150.0. Both are less than $40 and no sharpening - just replace the blade when you need to.
Steve
Japanese saw is like a woman..
You have to 'pull' her toward ya to get the most out of it!....
Duke -- I have a dovetail saw by Adria and have been pleased with my ability to cut very exact dt's. The dovetail saw is set for rip cuts (which I believe is important) as opposed to their tenon saw which is set for cross cuts.
