I need to make a replacement leg for a duncan phyfe drum top table. What is the best method to make the concave surface where the leg meets the vertical pedistal?
Thanks!
furndr
Thanks!
furndr
Use a carving tool with the proper sweep.
J.P.
J.P.
Thanks for responding. Unfortunately I don't have a carving tool that large. I do have a smaller gouge that will get me close to the final shape. I'm thinking about turning a cylinder on my lathe that is the same diameter as the pedestal, putting an abrasive sheet on that and sanding to final dimensions. The problem with that is I don't want to glaze the wood so that I don't get good adhesion.
Thanks again.
I'm confused. Isn't there a dovetail that holds the leg to the pedestal? In any event the glue adhesion between the almost end grain of the leg and the pedestal isn't going to be the thing that keeps the legs on. Of course if the legs are doweled, keeping them on will need every help it can get.
Steve,
You're right, most of the true antiques do have dovetail joints. However, this one was made probably 75-100 years ago and has dowels. I realize that the glue won't help much but it's about all I can do.
Thanks.
A cylinder will work or just transfer the radius to a piece of cardboard and make a sanding block from that.If the table is pretty old then the column is probably not round anymore due to wood shrinkage.Gouges and a sanding block will get you there.I would probably use 100 grit paper to fit the leg. No need to worry about burnishing the end grain and the surface need not be smooth enough to finish anyway.J.P.
J.P.
I like your idea of making a sanding block. Going that route will rule out the problem of burnishing the wood too much and also give greater control than holding the leg on a spinning cylinder in the lathe.
Thanks for the information!!
Dan
