I have a cabinet made by Bertch cabinets. I plan to modify the drawers and would like to be able to match the factory finish when I’m done. I know it’s some kind of cherry stain on cherry and catalyzed lacquer, but at least so far, they haven’t divulged the recipe. Any trick to be had here?
take a sample of the factory finished wood and a 2 square foot piece of raw wood into a high end finish supplier, they should be able to match it well.
Custom Cabinetry and Furniture
http://www.BartlettWoodworking.com
Contact them to "purchase" some of their stain. Many companies will sell their stain, along with the top coat finishes. Plus, most companies spray their stain on. This will make a diference in the final color.
Try contacting a local "Mohawk" or "Behlin" supplier. Many companies use their products for their finishing process.
Quickstep,
About a year and a half ago someone asked about a factory finish on cabinets ....one of the responders happen to be knowledgeable about the process....I think there were 22 steps with more chemicals than found in store bought white bread and lots of heat, pressure and vacuums....in other words, impossible to duplicate with out the same setup. It would seem your best bet has already been suggested by the other responders...good luck
Luckily (maybe) the finish I'm trying to duplicate doesn't appear to be too adulterated. It's not monochromatic like some factory finishes. I think I'm going to try to get some stain and lacquer from the manufacturer. Failing that, I'll try a light stain and shoot a high quality catalyzed lacquer and see what happens!
