I’m moving to Boise, Idaho & pland to set up my shop in a 2 car garage.Would like to put all tools,miter saw, drill press,band saw, mortising machine,radial arm saw 12”,scrol saw, on 30’wall. Planer, table saw &joiner will set up in middle of room. Need help with make,model & size…noise level at a minimum.Any articles I should look up? Thanks a head of time.Tank
Bill Pentz's site has a wealth of info on it (kinda hard to wade through, but worth it). Unfortunately, I just tried to get there and got a "cannot be displayed." Hopefully this is temporary.
http://billpentz.com/woodworking/cyclone/index.cfm
Thank you Forestgirl, what a great site!!!Tankcount your fingers at end of day --have 10? --you've done good
Any chance you could make a little lean-to on the outside of your garage?
PlaneWood
PlaneWood :Thats a possibility what did you have in mind? Tinkcount your fingers at end of day --have 10? --you've done good
Put your DC outside. Much less noise and residual dust in the shop. Also, when changing bags you don't get dust all over the shop. (I use plastic bags on mine for the bottom bag)
