a question on dust collection , which is better,bag or filter and how long will the filter last before you need to replace it Santa said if I am good maybe a dust collector , so trying to decide which way to go
Well many moons ago I purchased the style that has two cloth bags. I used this fro about 10-15 years. Back then, the bags were not rated in fine microns like now, so everytime it woud fire up a puff of dust would come off it. I eventually decided to upgrade the bags to a canister model (1 micron) with a plastic lower bag. I paid almost as much to upgrade to the canister as I originally paid for the KUFO DC. The difference is night and day. Mine has an enternal device that you can spin around to clean the filter cartridge out. I would also reccomend an air filtration system. You will still get particulate in the air no matter how good your DC is. I have the Delta unit and its a nice addition. The lungs are worth it. Good luck.
I agree with Bones. The canister filter is way better than the bag. Even if the filtration (1 or 2 micron) is the same - the canister filters have way more surface area. More surface area = more air flow.
With the cloth bags, your CFM drops as the bottom bag fills. With the canisters, your bottom bag is plastic, therefore, you don't see the CFM loss.
Clear as mud?
I have only used a cannister-filter DC, but have always wondered about even the best bags at the point where you have to empty them, and cope with all the dust that flies around then! Cannister filter system is so convenient, in addition to being very effective. Cannot even imagine messing around with bags.
FG -My old DC was a Jet 650 with a 5 micron filter bag. (I bought the cloth and SWMBO sewed it up for me.) That sucker was a real bear to empty and clean. I would shake the bejesus out of the filter bag and let things "settle" for a few minutes before I took it off, but I still got a lot of dust. If there was little to no wind, I would take the bag outside, turn it inside out, and shake it out.I had to pick my spots for that, however. My neighbor had a black car that showed every speck of dirt. - lol
I have the delta ap 400 and was able to find a cannister filter for it on an amazon sale.
Cannister filters are much better than the bag. I still have a bag to catch the sawdust but I feel better knowing my filter is a 2 micron filter.
Webby
I have a similar question for you all, as I may be buying my first real DC soonish. I understand the performance difference between bags and pleated filters and it's something I've experienced with my shop vac, but my question is how much of a difference would I notice between and good, 'conventional' DC with a cannister vs. an entry level cyclone? I think there is a portable one that could also be wheeled around the shop.
Thanks.Brian
As I understand it, the main advantage of a cyclone is the separation of the "chunks" from the dust which lets you empty the DC less often - and reduces the probability of dinging the impeller when a "chunk" gets pulled into the system.I would be reluctant to get a "roll around" DC. That will have you changing your setup every time you move to a different machine and - if you're like me - you'll be telling yourself that "One quick operation isn't a big deal" - lolMy first DC was a Jet 650 cfm that I tried to use as a "roll around". After a couple of months, that became a real PITA and I built a hard piped trunk system with gated ports at each machine and my bench. I still had to open/close the gates, but that was much less aggravating than moving and connecting the DC.Last year, I stepped up to a Jet 1100 with a Dust Dog pleated filter and made some improvements to my ducting. I saw a significant improvement in the collection effeciency and it even works with two gates open. - lol
The "Portable Cyclones" are pretty new to the market and I'm not sold on the idea.
They pretty much do the same job as my 1 1/2 HP Jet (cannister), have similar CFM ratings and can cost twice as much. IMHO, the benefit of a cyclone is the increased wood-chip capacity, fine dust separation, greater CFM ratings and continuos duty motors (class F, I think). Ask yourself:
How many CFM's does it take to collect the dust at my tool (guessing 350 is a good average)
Are the tools mobile or stationary
How many tools are going to be connected at one time
Do you need to increase your electrical capacity
My Jet 1100 can run my 10" jointer and my SawStop, at the same time... I wish I could :0) Don't get me wrong, I want to upgrade to a cyclone... I'm just not ready to drop $1,500 for the unit and another $1,000 to 1,500 for fittings.
Just my 2 cents.
"They pretty much do the same job as my 1 1/2 HP Jet (cannister), have similar CFM ratings and can cost twice as much. IMHO, the benefit of a cyclone is the increased wood-chip capacity, fine dust separation, greater CFM ratings and continuos duty motors (class F, I think). Ask yourself:How many CFM's does it take to collect the dust at my tool (guessing 350 is a good average)"Bill Pentz saids somewhere in the neighborhood of 800 cfm at the source is the minimum one should have for adequate dust collection.
A good cyclone system will shake out virtually everything from the airstream before it hits the filters. As far as I know the only system on the market that will do this is the one marketed by Clearvue.
lol, show me a non-industrial table saw that pulls 800 cfm through a single 4" port. I agree that Bill P is the man... but... take a look at your manufacturer's specifications before you start quoting third-party (AKA Bill) information.
Here is what I was responding to: "...Is a "portable cyclone", in your opinion, worth the money - compared to a cannister equipped collector?..." Now I'll ask you the same question. Is a "portable cyclone", in your opinion, worth the money?
I realize a stationary 2 or 3 HP cyclone is ideal (or a 5 hp CV)... no argument. But would you drop an extra $600 or $800 bucks for portable mini-cyclone that sends less dust to the filter - vs. a cannister collector. Also consider that a few turns of the paddles is all it takes to clear the dust? Everything else, including the machine connections, is the same.
"lol, show me a non-industrial table saw that pulls 800 cfm through a single 4" port. I agree that Bill P is the man... but... take a look at your manufacturer's specifications before you start quoting third-party (AKA Bill) information."It is entirely possible to get on a table saw. Maybe not through a single 4" port at the bottom of the saw but who saids it has to be 4"? I cut a bigger hole on our saw to accomodate a 5" port which pretty well cleans out the cabinet. The dust shroud around the blade is a 4" pick up. Combine that with a 4" pickup on the Exactor overarm guard and I'm well over 800 cfm and under most conditions no overspray off the top of the blade.
did you miss the question?
The cannisters have 5-6X the air flow of even upgraded bags. I've used the stock 30 mic bags, then upgraded to some aftermarket 0.5 mic bags, and then added the cannister. The cannister has better airflow, comparable filtration, and allows use of a plastic bag on the bottom without loss, which is easier to clean.
