i am very very new at this and i want to learn at lot about woodworking, but my main concern first is buying a dust collector. i saw a Delta brand 2HP with 1 micron filtration for about $600 volt is 240. and checked habor freight tool store 2HP with 30 micron filtration for about $200 with 110 volt. i can see the difference, but is the more expensive worth getting since i am thinking of getting an air filtration too? and considering i am very new at this and will definitelfy continue to learn and be a wood worker as a hobby only. i just want an advice, since there is a big price difference. and also i want to put this in my 2 garage where i will do most of my work. thank you
What other large tools do you have? TS, BS, Jointer, plainer? What are you going to use the DC on? Is your shop outdoors or indoors? Have you looked on Craigslist.org?
table saw, miter saw, sander, router not a lot yet yet but eventally i will get them
I am a firm believer that the money spent on dust collection and air filtration is the best money you will spend. Look around and find some comparisons of the different brands. Particle size for the filters is the major factor but also look for things like noise level (you tend to not use the noisy ones, plus keeping your hearing is pretty important also), ease of cleaning (doesn't work if it's not cleaned, and you tend to avoid cleaning the hard-to-clean ones), wiring (with switch or is it extra), and size of inlets. If you are setting up a new shop once you get a basic tool layout get a DC system designed and let that be your first purchase. You only have one set of lungs, make the most of them!
Spoken like an ex-wood shop teacher that can still breath, and I know of many that can't!
Ray W.
thank you for your advice
The better filtration (smaller particle size) is definitely worth the extra money. You want to capture as much of the dust at the source as possible, and the smallest particles are the most dangerous for your lungs (they stick in there forever; think oxygen bottle). If you rely on your air filter to pick up the <30 micron dust, you'll be leaving way too much of it circulating for your lungs to pick up as it travels to the air filter.
I have a canister-filter model Jet, which filters down to 2 microns. Even at that, I'm seriously considering housing it outside the shop so that the stuff that gets through isn't in my air.
Check the Tool Guide area of this Web site. You'll find at least two articles on dust collection, including a test of 1-1/2 hp machines and a dandy overview that can help you figure out the proper size and filtration for your shop.
Good luck,
David Heim
I don't think dust collection shold be your main concern when learning woodworking.
Work careful - no matter what you do. Many basic tools beginners use don't create dust -
SA
