Hello All,
I’ve never posted before, here or anywhere.
I have a question about grounding a poratable dust collection system for a small basement shop.
I’ve read that if using PVC, one must ground both the inside and outside of the pipe. Makes sense.
If plastic fittings are used in metal ductwork system, jumper around them. Continuity of the ground system. Makes sense.
A specified dust collector hose has a metal wire spiralling around inside the plastic. As far as I can make out, this wire is to be connected on each end to the ground system. Makes sense.
So, how does the dust collector hose with its wire spiralling through the plastic, ground the inside and outside of the tubing, as one is to do with PVC? I don’t see how this internal wire could drain off static. That makes no sense. Can anyone help me with this?
Thank you.
-Jonnie Boy
For a first post, you picked a real doozey - lol. Grounding DC systems and the reasons for doing it have been the subject of numerous threads on here.
If you're grounding to avoid an explosion in your DC, save yourself the hassle. There's no evidence that a spark has ever touched off a DC.
Grounding to avoid a nasty shock from the static buildup on the DC piping might be a good idea if you have that problem in your shop. I rarely see any accumulation of dust on my DC piping so my system isn't grounded.
That is just classic me! I've been researching this topic on and off for days! Thank you for a straightforward answer. I might just get to like this stuff.
Oh, I'm sure that someone else will chime in with a horror story about an ungrounded DC that exploded or caught on fire. Usually, however, these stories are anecdotal and involve someone's neighbor's, cousin's, ex-wife's, former boyfriend. - lolAs I said before, I rarely see any accumulation of dust on my metal and plastic DC piping, but I do see it on the shop vac hoses and tools when the weather is right. I suspect that is due to the much higher air velocity in the shop vac. Most of that drops off as soon as I shut off the vac.
I know what you mean about the static build-up on the shop vac. I've seen that this winter. I'l let you know how the dc installation goes. And thanks again.
Click here for an oft-cited (by me and others) presentation on "Grounding PVC and Other Dust Collection Myths." Just to wrap up your research, LOL.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
That is so excellent! Wow. I had never heard of this article. It fully answered my questions. Now I won't be working down in my shop tomorrow thinking, "Okay, but what about if the dust is from walnut versus oak?"
Now I won't be working down in my shop tomorrow thinking, "Okay, but what about if the dust is from walnut versus oak?" Too funny!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
I hooked up DC system in my one man shop last year with PVC pipe, there is lots to read about your question. What I learned was it depends on how dry of a climate you live in, if you hook up your DC system and you never get a shock from your planer or other tools I would not worry about grounding it. Myself in central Alberta I could get an arc over a inch long off of the handle on my planer, not much fun, I wrapped grounding wire that I bought at a local hardware store (cheap stuff)around the outside of the PVC and hooked it to the wire that runs through the flexible hose and then from the flexible hose to each machine, I have never had a problem with static since a ran the ground wire. I would not run a wire inside the PVC though it is just something for dust to collect on and plug up the lines. There are people that say you must run a wire on the inside and the outside and drill holes and put screws through to attach the two wires every so far, I never bothered with any of that and have not had a problem. It is easy to run the ground wire after you have everything together. No mater where you run the wire you can not ground plastic.
Thanks Mike!
I have had my Grizzly dust collector hooked up to 4" PVC pipe for 3 years. My house is stiil here and I have never received a shock from any equipment.
But, sawdust can ignite with some serious explosive results.
Unless you plan on tossing a lit flare into the PVC pipe, I would not be overly concerned.
But if you want to see what happens to sawdust when mixed with a high volume of air and an open flame, check out the Myth Busters video! Wicked cool!
http://www.youtube.com/watch?v=yRw4ZRqmxOc
Thanks! I'll watch the video. Forestgirl forwarded the url of an exhaustive paper on the subject. It was very good.
Whoa! That's quite spectacular!
