I’ve recently installed a dust collection system in my home shop. The ducting is all spiral tubing with the exception of a 2′ section connecting the main duct to the DC. This contains a grounding wire from the metal tubing to the collector BUT, do I need to do the same for all the plastic flex lines from the branches to the various machines? The lines vary from 3″ to 7′
Dale -
There are probably people here with more expertise on the subject than I have but .... it's my understanding that the grounding wire dissipates static electrical charges built up from the dust passing through the ductwork. So long as the main part of your system is grounded, I don't think the short lengths between the machine(s) and the ducting is a concern.
From Beautiful Skagit Co. Wa.
Dennis
This has been discussed here before, and I think Dennis is right. However, I too use this kind of system, and because I am a cautious guy, I opted to run a jumper around all the plastic fittings. It is certainly easy enough to do.
CHeck out this link. There is a lot of info there.
http://billpentz.com//woodworking/cyclone/Index.cfm
There are more old drunkards than old doctors. Ben Franklin
Thanks to all, this looks like a good site. Didn't mention that I did jumper the few plastic fitting that I do have so will carry on making sawdust.
Cheers Dale
Dale,
I use PVC pipes against the ceiling, with flex hoses only on the branch connections, because hose presents so much more resistance to air flow. I have no grounding anywhere and have never noticed any static build up.
Good to know, thanks.
Dale
