I have a HD Dust Stopper connected to my 6.5 hp shop vac. I have it on a HD bucket – no gasket. I am only collecting about 50% in the dust stopper. I have been using a power planner lately and hand planes ( I use it to sweep up after) as well as a random orbit sander. The power planner does throw out a a lot of shavings at once. Any ideas what to do?
Separators rely on an air tight pathway for best performance. A gasket would be my first step. After that if too much spoil is still getting by I would vent the vac a bit to reduce the suction. The vac may be overpowering that separator design. I use a pair of Dust Deputy's and a pair of 6.5HP Ridgid vacs. The separation is so good I tossed the barrels and build small filter boxes to reduce the footprint. I get about a shot glass of spoil past the DD and into the filter box every six months or so.
Thanks for the feedback. I will try the gasket.
I have the same setup. Wiping the lid and the bucket of dust helped me.
Where do you get a 6.5HP Shop vac? Are they three phase?
A too powerful shop vac can pull stuff right through.
440, 441. Whatever it takes.
thx
I made this simple cuff-type vent/bleeder out of some shop-vac sized parts. It is installed before the separator. In my case it is just to reduce the vacuum when using the system with my ROS. There is so much suck it will slow the sander or the sander will actually pick up small parts when I am working. In your case it may reduce things so that the spoil falls out of the air stream inside the separator better.
Good ideas here. It is a 6.0 not 6.5 peak HP from Rigid. It may be too much for the Dust Stopper. Thanks for the photos- these are big help. I will try some of these ideas.
@Rob: most shop vacs sold nowadays (in the US, anyway) use "Peak" HP ratings - which should be interpreted pretty loosely as it will only create that power for a very brief time. This "Peak" is probably 2-3X its normal, sustainable power level.
Hi everyone. Wanted to let you know I sealed up the bucket and things are working much better. Thanks for the help.
Great. Thanks for closing the loop.
Gotta get me a 3-phase 220V shopvac.
