Does anyone have advice on how to start dyeing cherry sapwood to match heartwood? Any help would be appreciated.
thanks,
Stevo
Applying the dye by hand or with a spray gun?
http://www.finishwiz.com
If you really need the cherry to not have color variations, you need to leave the sap wood in the scrap box. The problem is that while you can dye the sap wood to match today, it won't match a year from now because the heartwood will darken considerably, and the dyed sapwood won't. Alternatively, arrange the sapwood so it makes an attractive pattern.
You can do like furniture manufacturers do and use a nearly opaque stain over the entire surface, but then why use cherry to begin with.
There was an article specifically addressing this written in FWW some time ago. Good luck finding it using the search engine, though. I've not been very successful in the past even when knowing the exact article.
Pascanale
Try Homesteading Finishing"s web site. Jeff Hewett has a good article on this subject.
