Has anyone tried the http://www.taunton.com/finewoodworking/pages/w00117.asp
what do you think about it?
It is easy and the finish looks and feels terrific. I have just started using it so I can't tell you how it will look in 10 or 20 years. But others who have indicate that it holds up nicely. I've used it on a cherry wall unit and other cabinetry where it will not get a lot of abuse.
Alan
Can you do the finish on an assembled project like a blanket chest or should you do it before assembly?
Ron61,
Several months ago there was a general discussion about spar varnish. Someone in that thread said that spar varnish never gets really hard...that given its purpose, boats, removal and re-application is an objective. I don't know if that is a negative or even true but I remember that comment.
If you want an easy hand rubbed looking finish on new wood, I would suggest Waterlox..six coats. I've done several ash pieces and love the look and feel. However, my objectives may be different than yours. Good luck
I use this basic process, but not the spar varnish for an interior piece. Yes, it has UV protection, but it is a long oil varnish, and doesn't harden as much as a regular, gloss, interior varnish. Fresh varnish is a must. Mix up a bunch, and use it up within 1-2 weeks. Or, throw it away. Varnish that is left over will not dry as well is my experience. Some add oil, and call it an oil varnish mixture. I have done this also, but now delete the added oil as unnecessary, and a furhter drying inhibitor. If it starts to tack up too quickly, add more of the mixture, or put a bit of mineral spirits on the wiping rag.
