Howdy all. I am wondering what is the procedure for putting a different colour (color for those of you south of the 49th)edge banding on cabinet carcases? The carcase will be made from pre finished maple ply, natural coloured but the edge has to match the doors, mahogany colour. do i stain the banding first, then iron on, then laquer? do i stain and laquer first? do i put it on naked then stain and laquer? I will be using an iron on product.
thanks in advance
Tmaxxx
Urban Workshop Ltd
Vancouver B.C.
cheers. Ill buy.
Hi tmaxxxxxxxxx
I have in the past applied raw wood as you're suggesting. Don't assemble the cabinets. Iron it on, sand any burns, assemble cabinets, stain and finish like usual wood.
Around my shop I'm able to buy pre-finished edgebanding then apply it with pressure sensitive adhesive. Maybe you can find that?
tmaxx,
I have never prepared cabinets as you are going to do, but I have differentially stained wood as you are going to do. There are several ways you could go about it. The primary consideration, of course, is to keep the dark stain off the maple. Not a small challenge.
Since the maple is pre-finished, you already have a leg up. If it were not pre-finished, I would cut it oversize, finish it, then cut to size before edge banding.
Be sure the finish is really sealing the maple. If not, add another coat of finish, whether lacquer or varnish (you can test by applying the stain to the maple ply).
Before you cut the ply to size, apply masking tape overlapping down the cut line (on both sides of the ply) and burnish it down. This will mask the edge of the ply perfectly when you cut it. Carefully apply sanding sealer with a small brush down the edge of the veneers, avoinding getting too much onto the edges of the inner plys.
Then iron on the edge banding and stain it. Then remove the masking tape from the ply.
The easier way, of course is to stain the banding first, then iron it on. Stain a piece and test your iron-on technique to find the right temperature and speed to avoid any burning, yet getting a firm glue bond.
Rich
Edited 11/19/2006 3:00 pm ET by Rich14
At the risk of asking a really dumb question, why not use mahogany edgebanding?
DR
Sems like a good solution why notYou can make it fool proof but not idiot proof
I think that is his intent.
Hi, Tmaxxx,
In my shop I use a lot of prefinished plywood for carcasses, maple, oak, even cherry. I also use prefinished edge banding. It is available in many different species. Most of the stuff I use comes from a company called edgemate. I get the prefinished edge banding from the same supplier I get my plywood from.
Good luck,
Jpat
jpat,
Where do you get your prefinished plywood? I'm having a hard time finding a source.
Mike D
Try fastcap or walzcraft
If you don't want to hassle with finishing your edgebanding you might look into polyester edgebanding from Tape-Ease.It is paper impregnated with color to match any wood species and stain. It's available in iron on and stick on. Rob
