Hi,
After reading the responses to my last post I’ve decided to go with an edge guide for cutting dadoes rather than the table saw. Considering the length of the board. I think it would be safer for me since I am not that experienced with the saw.
Is there any particular brand you would recommend? I’ve come across 2 online I’d be interested in purchasing. 1. Canwood.. Edge clamp guide single or doube… Would it be better to go with the 50″ double ($49.32 Canadian) What advantages does that have over the single edge clamp guide. 2. Clamp’n guide (from Rockler) Looks good. I’m leaning towards buying that one. 50″ guide. Cost’s $39.00 US which would cost me approx. $54.00 Canadian.
Wendy
I wouldn't recommend either one. I would suggest getting a good book on router tips. As far as edge guide I think you can make a much more suitable one from scraps. A standard technique is to make a t-sqare from plywood or what have you. When you make a test cut you will plow a groove in the t part of the guide which will serve as a reference to line up the guide for future cuts. The T style keeps it lined up square and it's very simple to use. All you need is a couple of clamps to hold it in place which you should already have.
Wendy
You could go to the Hardware store and buy a piece of Aluminum Angle in about 6 or 8 ft long.
I prefer the 1 1/2 inch stuff, in 1/4 inch.
It's cheap, quick, and works as good as the ones you buy.
Just clamp it on and you have a straight edge to rout against.
Just check for flex first, so you know how hard you can push against it.
I am not a big fan of the clamp guides either. The guides move just a little bit even after they are securely clamped down.
I have had better luck with the blue plastic and aluminum guides from Peachtree in Atlanta. They don't seem to move like the common ones that are sold everywhere. They also have a ruled tape and a T-slot across the top which makes them a bit more functional, for example if you want to attach a stop.
The best is to make a really good T-square version from some MDF and a piece of hardwood - depending on how long they have to be.
Jeff: Be advised that the hardware store variety of aluminum shapes is likely not as straight as you would like. After the extruding process,the shapes for basic construction ,do not go thru the straightening process as do those designed for tooling.When cooling down, the angle shapes,tend to develope a curve along the edges due to the shrinkage of the metal.The flat shapes of the straight edges in the catalogs,being of more equal cross sections,are much less likely to distort in cooling. Also,these extrusions are gripped on each end and strecthed to the point that they remain relatively straight and even.If you are not familiar with the process,think of it as squeezing tooth paste out of the tube.
Work safely¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬
Pat
Never thought about it.
I'll need to look at a piece.
Wendy,
I bought a set of 5 Clamp n Tool Guides at a WW show years ago. Love them, use them all the time with the skill saw and router.
Before those I used the extruded aluminum straight edge used for scoring drywall. Two pieces about 54" each and a splice to connect them end to end. Still use it for work over 50". I'll guess $20 as a current price.
Enjoy, Roy
