Is there any company that makes router bits to create dovetail joints like the bits for tongue & groove flooring? The early Model As had dovetailed floors that I’m trying to recreate
The router bits commonly available can do that. Look up "sliding dovetails" to see how. It is more about getting the machine setups dialed in than it is about the bits.
I get what he's looking for, like a t&g set except it's dove tails. My set up for that is two routers two tables and two identical bits. Cut your groove , fuss around until the tail fits the groove doing one face flip the board and do the other face. You don't have to tear down one set up to do the otherside this way and you can complete a whole board in one go.
Thanks for the info!!
Pre-cutting the "groove" before running the dovetail bit down the center will make cutting that part tons easier.
Good comments and suggestions above. There are several ways to make sliding dovetails using a router. I made mine with one router table and two routers, one with a straight bit, another with a dovetail bit. I was trying to reproduce the classic French charcuterie boards that I 'think' had a sliding dovetail, cross grain. I was using hickory because it is what I had on hand. After about 10 runs with scrap wood I got OK results - or you could say,"needs improvement." They are supposed to be rustic, right? I ran the dovetail in, pegged the tight end with a dowel, and expected the other end to float. I hope to revisit this again in the near future. Good luck!
A horizontal router set up would be good for this.
