Hi
Can you edge joint oak plywood?
Making shelves they need to be square.
Thanks for the info. Bob
Hi
I do it occassionally but prefer to cut with a fine cut saw that leaves no visible saw marks. This surface is usually smoother than a jointed edge because of the tear out of the end grain on some inner plys. I have found that jointing plywood often puts nicks in the blades, but not always.
To stop the back edge tearout, feed a piece in about 1-2" then lift it off. Flip it around so that the scallop you just cut is at the back edge. Then run the piece through the whole way.
If you build it he will come.
Another way is to use a hand held planer with an edge guide.
Similar to this, but you can use just about any straight edge and a bracket.
david.
You'll find that edge jointing plywood dulls the knives very very quickly.
Thanks to all who answered.
Looks like I will be using the table saw.
http://www.eurekazone.com/products/detail/sgs.html
With a good blade and circular saw. Stop wrestling sheets of plywood through the TS.
Dave
Edited 12/15/2006 11:44 am ET by DaveRicheson
I use a Forrest WWII blade on the cabinet saw once I trim it down with the CS, and it gets it glue ready. Another idea is to use a router with a strait edge. I used this before the Forrest blade. Good luck.
