Hey all,
I’m working on (among other things) a trestle-style dining table wherein the top is tiger maple. I’ve been having a really good time working with said tiger maple, especially hand planing the joints. And, as I approach detail time, I’ve been considering the edge treatment I would like to give to the table top. I think this consideration was further sparked by Garrett Hack’s article in my new FW. Love the bullnose/bevel combination and would really like to try it, but am wondering if anyone has suggestions on how to attempt this with my hand planes and (here’s the real question) NOT TEAROUT!!!!! I’ve hand-planed bevels, chamfers, roundovers, etc, before even on large pieces, just not on ornery wood. So, if you have any advice, I’d love to hear it!
Thanks all,
And Merry Christmas!
Jordan
Jordan,
Bullnose is easily approximated with the high angle plane you used to make the gluelines. So is the bevel. You could make a template, and a scraper to refine any variations from your ideal edge shape if you need to, but I'm guessing you can get close enough "by eye".
Alternatively, if you are of a mind to, you can make a high angle molding plane to do it in one swell foop.
I'm using a 3/4 " bullnose router bit from Infinity Tools to add a bullnose to my curly maple piece. So far I'm not experiencing tearout on my test pieces, and this is pretty fiesty wood. In a couple of days I should be trying it out on the real thing.
I struggled with how to use the router to put the bullnose on such a large piece. The piece is a bit unwieldily to do on the router table, and there's no convenient place to guide the bit's guide bearing when using it in the hand held router.
Finally, it dawned on me that my router's edge guide (Bosch) has a split fence and that I should be able to successfully cut the bullnose with the router hand held by setting up the split fence and bit relationship on the handheld router in the same way that I would, were I to cut the bullnose on the router table.
We'll soon see if practice follows theory in this case.
Mike I think the router --hand-held and very light cuts is the way to go for the basic stock removal. After you get close to the profile you want, like another knotter said- make a scraper and zero in on the final shape. Curly maple will work well with sharp router bits if you take a little at a time. Finish with hand tools to get your exact profile and you should be in there.
dan
Thanks all,I'll probably try doing this with my hand plane as suggested for a couple of reasons. I really enjoy the look and feel of a finished piece that looks like someone made it and touched it at some time. Secondly, I'm pretty router illiterate. Learning, but still can only say my alphabet- can't identify the letters and definitely can't read outloud!!So, it seems like sharpness is the key on figured woods.
Thanks again!
Jordan
Jordan,
Sharp, plus a light cut, at least to finish up with.
One tip I might add is to wet the wood before you do any cutting with either a hand plane or a router. I have found that just wetting the surface with water reduces tearout dramatically even when using a planer or joiner. I think this is because it reduces the brittleness of the cross grain.
Um, I'm kind of scared of rust? Especially on my precious handplanes.
A wipe down with a dry towel and then with wax, WD 40 or another non-silicone agent will minimize any potential rusting. You don't have to have standing water; just enough to dampen the wood surface. I've never had a rust problem from using my tools on damp wood; only from the normal New England weather conditions which require constant preventive maintenance on all my equipment and tools.
