I was just given a Lie Neilsen edge trimming plane — with the option of exchanging it for something else if I don’t want it. Does anyone have any experience with this tool? How useful is it? My plane inventory at present is a Lie Neilsen low angle jack, an ECE smoothing, a Veritas medium shoulder, and a Stanley block plane — all really useful!
Joel
Joel,
Without any comment on gifts like that just materialising from nowhere-
Depends on what sort of work you are doing, but although that edge plane is very useful it is not that often required, compared to the little L/N scraper plane #212. Costs a little more, but is more often called for in my experience anyway.
I find its does a very good job on endgrain. I feel it is a handy plane when dealing with narrow boards such as drawer sides where their is not much bearing surface for a larger hand plane. As someone else has mentioned it really depends on what type of work you do. I don't use it often but when I do I am glad I have it. It can be a little tricky to set up for a square cut as you have to adjust the angle of the blade along with the depth but once set work great.
DITTO...
I've had one for many years. I don't find any use for it because I have many other planes and power tools. My Father loved his. He doesn't have as many choices in tools and he uses it to clean up edges after a saw cut. It does a nice job for him, keeps the edge square and only takes a pass or two.
