I’ve been somewhat looking at Emmert Pattern Makers vices on eBay, (they send an emails with new auctions)and a fair amount of them have welded repairs. If you’ve never seem one in person, these things are ~80-90 pounds. It begs the questions: How the heck are these things getting broken?!? I guess I can see the hinge breaking if it is used as an anvil. But how are they breaking the main square post going in to the head?? (which seems like the 2nd most common repair in these things).
Edward
I've owned a number of them from the turtlebacks to the newer style. Down to 3 at this point, none for sale!. The broken ones I've seen were probably dropped or overtightened. Most of the breakage i've seen is corners of the vise missing or sprung jaws. If they are broken at the post I'd say someone really leaned on it. I see this happen to regular vises and an Emmert is definitely more on the fragile side.
The vise jaws aren't terribly overbuilt so the can be sprung with over tightening and especially if you go to far from the center where the spindle is.. Used properly they are fine. They probably could have been made more robust, say 150 lbs and they would have been heavier duty. The Yost is supposed to be heavier. Just seen pics of that one. Oliver made one and there is a newer version being produced for several grand. I never paid more than $250 for them.
Folks usually lose the angle plate or tilt arm mechanism. There's a guy in PA who sells some parts and the angle plate are being reproduced and can be found at one of the Emmert sites out in cyberspace.
Edited 5/25/2006 4:27 pm ET by RickL
I have a Yost, (turrtle back style), and it looks to be a bit heavier than the same size Emmert. I have not been able to hurt it.
I've picked up an Emmert myself and finally have it restored, almost! Check out http://www.mprime.com/emmert A very interesting site on the Emmert Iron Hand. There are some links there also to other Emmert sites. Old printed material, Instalation methods and hours of reading. I think one of the reasons for some of the breakages is the replacement of the original Beech handle with a 1/2 " length of Pipe. I turned a new currly maple handle for mine, A little over the top but it sure is pretty and I'll break the handle before I break the vise. A common break point is the clamp for the tilt arm, One of my problems. I have the Type ll.
Bruce S.
