Hey gang,
I recently installed an Emmert Vise on my workbench. A type 1 model U5 to be exact. I love the vise as this is my first time working with an Emmert. Thanks being said, I am having one problem…..racking when clamping a small piece in one end. I typically encounter this problem once I spin the vise so that the long axis of the jaws is pointing up and down (i.e. to clamp in a small piece for carving. I recognize that there is a built in tilt mechanism that allows one to grasp odd shaped and angled pieces; however, I can’t find a way to lock this tilting mechanism in order to prevent the racking when a short small piece is only placed at one end.
Any thoughts??? Am I missing something?
>Thanks Being Said<
Thanks for saying thanks
Well . . . I was going to say what I am going to say later. But I was going to say it earlier. But that would just seem rude and unhelpful.
So
I will be helpful first and then say what I was going to say.
Don't worry if that is hard to follow I am just having fun with silly words.
Anyway :
Racking while clamping small stuff . . . did I understand that your vise has a built in feature ? I am thinking you mean the adjustable jaw tilt out of parallel feature. Or maybe you mean it has the one I am going to sugjest.
Hear is what I added to my "rails in the way" Record vise ( see the photo in the link of the all thread bolt through the corner of the front jaw (there is a nut imbedded in the soft wood jaw liner). This helps keep the jaws parallel when clamping on one side of the vise.
http://forums.finewoodworking.com/fine-woodworking-knots/general-discussion/record-vise-question
Now
I was going to say this is why I stopped using the rails in the way and went with a more realistic and useful woodworkers vise (s).
http://forums.finewoodworking.com/fine-woodworking-knots/general-discussion/tail-vs-end
A guy (or gal) needs more than one vise in my opinion.
These rails in the way vises are good for clamping big hunks of wood centered in the jaws , for what ever reason one would do that . . . working on wood forms for castings or what not . . . I would highly recommend rethinking the usefulness of the rails in the way vise for cabinet making.
I did.
PS: I am not a carver but maybe consider one of these :
http://www.leevalley.com/en/wood/page.aspx?p=31172&cat=1,41659,41667&ap=1
Give your vise a wedgie?
Another option would be to tap a wooden wedge between the vise jaws at the opposite end, once the vise has been tightened moderately on the workpiece.
I have a type T3 and it is my main vise and I don't know of a way to "lock in" the "bevel". But a fair warning would be NOT to put a wedge on the opposite end and create a gap in the middle when clamping. Emmerts are cast and you sure dont want to crack or break it. If you don't have a wood handle on yours, PUT ONE ON IT ! They originally came with wood handles for a reason, break the handle and not the vise.
