I am designing a bathroom vanity cabinet which will have an exposed end. My plan is to attach to the 3/4 inch plywood end of the cabinet a cherry frame and panel (3/4 inch rails and stiles). I am not sure how best to attach the frame and panel. Screws from the inside? Glue? I think the frame and panel should be attached after the cabinet is installed, which would make it difficult to clamp. Any suggestions? Thanks.
Hi,
I think screws from the inside will work just fine as long as the end panel and the frame are both flat. If any gaps appear at the edges then you might have to screw and plug from the outside to pull things together. Good luck. Gary
