I am making an oak stool for my son. In the center of the top of the stool I am routing out a handle. Going with the grain is no problem but every time I turn the corner and hit the end grain, the wood burns. My router bit is sharp and I am moving the router quickly. Is there anything else I can do to stop the end grain from burning? Thank you for the advice.
Take smaller amounts with each pass and if possible always rout the endgrain first. This should work, but if not, a shearing bit will cut those fibers more cleanly than a standard straight cutter.
Thank you for the advice. I was not familiar with the "Shearing Bit" so I have been looking at different web sites for this bit. None of them really explain what the difference between a straight bit (which is what I was using) and a shearing bit is. Can you help me understand what the difference is. Again thank you.
A shearing bit has the carbide edge at a slanted angle, so it "shears" the wood instead of cutting it all at once like a straight bit. Burning usually happens when cutting too slowly or with a dull bit, but is less likely with a shearing bit.
Of course, if you don't want to throw down more cash for tools, hand-sanding is always an option.
Edited 4/13/2004 2:44 pm ET by JACKPLANE
Thank you for the explanation, today you have helped me learn something new. Though, becuase I like to spend as little money as possible, I will probably end up sanding. I was hoping for an easer fix (I fit our society well:)) Again Thank you.
JP, aren't the shearing bits also referred to as "down-spiral" and "up-spiral" bits?? or is it a totally different bit?forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
To my knowledge, they're very similar but a shearing bit has a less aggressive slant while a spiral bit is a spiral along the cutting edge.
If there is an inside corner, you will always get a momentary pause when you hit the corner, and at 20,000+ rpm this will always scorch oak. The easiest way to avoid this is with a variable-speed router, just slow down the bit (that's what VS is for!). With a constant speed router you can get one of those $30 VS units.
Otherwise you will have to sand, scrape, or chisel the scorch marks away. Sharper bits, shearing bits, etc will minimize the problem, but with oak I think you will almost always get some scorching at inside corners when routing at full speed. I do, anyway.
"Everything should be made as simple as possible, but no simpler." A. Einstein
http://www.albionworks.net
Thank you for the advice. I do not own the router I currently am using but I will keep your advice in mind when I am able to finally buy my own router.
