Are there more detailed plans available of Lon Schleining’s workbench in the Winter 2003/2004 edition of Tools and Shops? I specifically need to know the distance between the trestle legs and the position of the trestle top member. Thank you.
It's not essential that you set them in an exact location. The top stretcher mortise should be about 1 1/2 in. of material between the upper tenon shoulder of the leg. The bottom stretcher mortise should be about 2 1/2 in. from the lower tenon shoulder of the leg
If you want to build a tool chest that sits below the bench in between the stretchers, then it will be more important to place the stretchers in an exact location.
Matt Berger
Fine Woodworking
How necessary are the top stretchers? I understand that, in theory, the top stretchers are meant to reduce racking. But if the top is fastened securely to the trestle legs and the bottom stretchers are tight, won't that be enough to avoid racking?
I would say the top stretchers are pretty important in this workbench design. You can expect that a workbench will get a good workout over the years with all the banging and force that it takes from common woodworking tasks, and the top stetchers do a lot to prevent the bench from racking or swaying.
