I don’t know how many of you people are Canadians, but I am wondering if you have a type of router bits down in the States that goes by the title “Exchange-a-Bit”? This same company also manufactures circular saw blades that are called “Exchange-a-Blade.” Is that ringing any bells? I am wondering about the quality of them. The basic premise of the company is that you buy the bit or blade, use it, and when it gets dull, return it and get a new one for up to %50 less money than a new one costs. For example, I have a 9″ 40 tooth table saw blade that I bought for $53, and when it wears out, I will exchange it for an identical blade for $24. The sme thing goes with the router bits. I used one on a project this summer (1/2 in round over, $50), and wore it out. I exchanged it for $32, and was back in business. Anyone have any experience with these, or is it a Canadian company only. They are manufactured in British Columbia.
Jon,
Sounds like quite a racket to me! Let's see, I purchased a 10" tablesaw blade for about $58US. I have had it sharpened twice for under $10 each time. So far, my investment is $58+10+10 = $78. Under the exchange program, I would have paid $58+29+29 = $116 plus shipping both ways (most likely).
Bill Arnold - Custom Woodcrafting
Good thinking! I was talking to a couple of guys on the job today, and they were not as impressed with the Exchange-a-Blade/Bit program as I thought I was. I did not realize that the blades were so inexpensive to sharpen (relatively speaking). Thanks for the heads-up on that!
Graham
Jon,
Another thing I meant to mention. You commented on a 1/2" roundover bit that cost $50 in your initial post. When I see prices in that range, I wonder how much one is paying for quality vs manufacturer's name. For instance, I purchased a set of four roundover bits (1/8, 1/4, 3/8, 1/2) several months ago from a catalog company. The set cost $30 and these are good quality bits. Individual prices range from $11 for the 1/8" to $17 for the 1/2" bit. At these prices, a bit becomes a throw-away when it has lived a full life.
Regards,Bill Arnold - Custom Woodcrafting
How long is the "full life of the router bit"? I was routing spruce 2x4 edges, and did about 200+ feet of board over a two and a half month period. I was careful to not damage the bit in installing it or uninstalling it from the router, and it was in its little box when not in use. It never touched another piece of metal. In spite of my care for it, it was burning the end grain, and badly chipping the end grain of the work piece. The carbide cutting edge was also chipped on one corner. A fellow employee mentioned that that particular bit may have been resharpened several times already, and that may have caused the chip. I will probably not get another bit like that, due to the bad experience and the recommendation of more experienced men than myself, but is that reasonable bit life or not? Thanks for your ideas on the topic.
Graham
"How long is the "full life of the router bit"?"
Not to be facetious, but the answer to that would be from fresh out of the box to totally unusable. Length of life will depend on such things as: 1)type of wood; 2)how it's used, i.e., letting the bit do the work rather than crowding it; 3)proper router speed; 4)care of the bit.
I've never worked with spruce and am not familiar with its characteristics. I have worked with woods ranging from soft pine to teak, however. Woods like teak, with its silica content, will degrade a bit much more quickly than others might. How many board feet could I run? Don't have a good answer for that, except that I was working on a project for a sizeable boat with all the furniture built of teak. Along with building some of the furniture pieces, I milled a lot of the molding and column parts which required 1/4" roundovers. Must have run hundreds of feet with the same bit and it was cutting fine when I finished. It was a Bosch bit that cost maybe $20. Other people in the same shop had a way of destroying good equipment because they had to demonstrate how "manly" they were.
As to how much a bit should cost to be sure it's good is an issue that will bring out the best and the worst in people of experience. Some people believe that the top-of-the-line, most expensive tools and supplies is the only way to go. I have a more open mind about it -- taking the price/value route. For instance, when it comes to something like a router bit I prefer to do what I described in my initial response -- get a good bit at a good price, then toss it when it's no longer doing the job.
Edited 9/20/2004 11:49 am ET by BArnold
The bit in question would have been about $38 US. Thanks for your thoughts. I really appreciate that. I am thinking seriously about getting a set of Lee Valley bits (12 bits for about $128 US ($170 Can.)), and that will probably be what I will use. Thanks for all the input. I don't think I was overly hard on that bit by pushing it too fast. It was probably just more money than quality for that particular one.
Graham
