Hi I just re-read a 1 to 2 year old FWW article w/ Jeff Jewett using paper towels to wipe on diluted coats of fasry dry varnish, 3 coats in 1 day! Has anyone done any of this? good things or bad things to say? What product did you use? Thanks, Dave
I've done it using Minwax fast dry poly, diluted with 25 - 50% mineral spirits. It works just fine, especially for turnings. Blue shop paper towels work well, as do softer regular paper towels. You can use a new towel for each coat or store it in a plastic container between coats. That makes it easier to quickly wipe on another coat from time to time. I don't like wipe-on for table tops though because there is very little build. For that I use a foam applicator or a brush.
The wipe-on method will also work using a light cut of shellac. I used it to tone one side of a highboy that I failed to put the second coat of stain on. You have to do it more quickly with shellac to avoid dragging.
This is the "50/50 wipe on varnish" technique. You can make your own by diluting equal parts of varnish with mineral spirits or naphtha and wiping it on. If you use a paper towel be sure to use one that is not patterned.
Do not thin a varnish such as Minwax wiping varnish--it is already thinned (so you are paying more for a diluted product basically).
The technique is excellent, pretty foolproof in that you don't have runs and drips. There have been many many discussions on the board about the process.
SW makes a fast dry alkyd varnish. It really does dry (to the touch) in about an hour. Wouldn't sand it that soon, nor recoat. Cut that with enough naptha and the wiping idea makes thin layers go on quick. But I get iffy on this - once it's dry, you gotta scuff sand it, so whats the advantage of multiple coats of real thin varnish. It works fine as a light finishing coat, but I guess I wouldn't use it for something other than that. Maybe I just need the proper level of enlightenment.
Hi The thought is fast dry minimizes duste exposuer so I can end up w/ nicer finish? Thanks for all your thoughts, Dave
Maybe I am misreading you but you do not need to scuff sand between coats of wiping varnish. Gretchen
Correct Gretchen. The beauty of wiping varnishes is that they can be recoated as soon as they are dry to the touch. Also, the can be recoated up to about 6-8 hours without needed to scuff sand. Over eight hours and it's best to wait 24 hours and then scuff.
Dave, any chance you could post the issue #??
Hi, It is issue # 143 Thanks, dave
Cool, I've got that one. Thanks!forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
