greetings friends.
So I purchased a HVLP sprayer that can be powered by my framing compressor. I have used it for dyes, and it works great. Can I safely spray shellac with a binder of denatured alcohol, or will I blow up or subdivision?
thanks
stephen
p.s. not that one less subdivision would be a bad thing….I’m just saying.
Edited 6/6/2007 7:41 pm ET by reefchild2
I have been spraying shellac and other products with dna for years and have not blown up yet.
Thanks, I just wanted to be sure.
me too - no xplosions yetjerry
Stephen,
Luckily, Fuel-Air explosions aren't that easy to create, however, they are spectacular when they do happen. The vapor/oxygen ratio has to near perfect or nothing much happens. (which is why we can use light petroleum distillates to light the charcoal in your grill without losing your eyebrows each time)
As long as you are in a reasonably well-vented room as you're spraying, you really don't have to be overly concerned.
Jim
Jim~
thanks for the humor and encouragement. I will give it a try, and espeically in fl, nobody would miss one less trac.stephen
I have been spraying all types of lacquer in a home shop for 30+ years with no problems. I use a squirrel cage fan to exhaust the fumes. I have a Devilbiss FinishLine HVLP gun (from Highland Hardware) that works like a charm. It cuts down on the overspray and save a lot of finishing material.
Once you get accustomed to spraying you'll never want to use a brush again, except for maybe the initial sealing with a washcoat of shellac.
If you have access to M.L. Campbell products give them a try. They work great and are very user friendly.
Good Luck!
furndr,
Funny I've been spraying for decades,, part of the reason I'm so much in love with shellac is the speed and ease it can be brushed. Now maybe you have a room dedicated to spraying, however for me I have to haul the gear out set up build a spray booth so the mist doesn't mess stuff up and then tear everything down and clean up afterwards.
Compared to grabbing a brush and slopping it on, the time involved is massive.. The cool thing is the lack of need to even clean the brush afterwards!
