Just something I did to ease my life.
My table saw is integrated into a 7′ X 8′ plywood table. The underside has storage, dust collection ducts and collectors. The saw is in the middle at one end with a router table to the left and about 24″ to the right of the cast iron extensions. The saw has a 30′ fence. Some times I needed to have more than the 30″ width for cutting so I would measure from the blade and screw in a length of aluminum angle to the table and their it was. My longer fence distance. I decided to make this a somewhat permanent and easier thing to accomplish so I routed and installed 2 aluminum tracks into the table and measured and layed down selfadhesive measuring tapes to the table. Now I can easily locate a distance greater than 30″ from the blade.
ASK
No pictures? ;-)
His description was good enough for me. I get the picture!Chris @ http://www.flairwoodwork.spaces.live.com
Ralph,
I was sitting in the office doing my early morning Knots review and it occured to me that this might be useful to some others so I posted it. If you really want I will take some pictures this weekend and post them.
ASK
I do the same with my old saw..
But no measuring tape! My auxiliary fence is a surfaced hunk of QS white oak. It has stayed straight for many years. I clamp it down with two big old 'C' clamps!
Yes, I do check it's flatness before I use it. It is the second one I made. The first curved a bit soon after making it.
Ralph,
You want pictures? I give you pictures.
I used it for the first time this morning. Needed to cut some shelves 38" wide.
Worked beautifully.
ASK
Excellent. The pair of images are worth at least 2,000 words. ;-)
Thank you. Any time.
ASK
first off, great idea, only problem i see it that: how are you sure that the fence will be parallel to the blade each time you move it?
I'm just sayin'
That's why I put the measuringn tapes down.
I also measured to the blad
ASK
I used to do something similar before I got my wide fence. I used to use the fence and a straight piece of wood, laid in between the fence and the auxiliary fence, to set up the auxiliary fence parallel to the fence and thus the blade.
I set mine up with a piece of scrap 3/4 plywood. I measured the width between the right side of the fence, and the furthest out I could put the auxiliary fence, and clamp it down. It turned out to be 21-5/8.
So, I cut a spacer out of the scrap 3/4 plywood 21-5/8 inches wide. I then set the fence at 1-inch, laid in the spacer, butted the auxiliary fence up against it, and clamped it down. This left the auxiliary fence parallel to the main fence.
I then ran a piece of scrap held against the auxiliary fence and the miter gauge into the front of the blade just enough to leave a little nick, and then measured from the end to the nick, which was 26-3/4. Taking off the waste inch, the offset using my spacer board was 25-3/4-inches, which I wrote on the spacer with a marker. I guess I could have ripped a new spacer so the offset was at an even inch, but I'm ok with fractions in my head so I didn't bother.
So to rip a piece at 37 inches, I would subtract the offset, and set the fence at 11-1/4. I would lay the spacer next to the fence, push the auxiliary fence up against it, and clamp it down. It was then parallel to the main fence, and set up to cut 37-inches from the blade. I'd pull off the main fence, and make the cut.
It doesn't appear from your photos that you've either a riving knife a splitter behind the blade (perhaps you took it out for the pictures, but there doesn't look to be a slot for it in the throat plate). Not sure if that's the case, but it's really, really dangerous to use a table saw to cross-cut long pieces without at least a splitter. All it takes is a little bit of mis-alignment, and the blade will launch the piece at high velocity. The FWW videos on kickback illustrated this pretty well.
Thanks for your concern. I removed the splitter because doing some other things on the table. Yes Yes I know how dangerous it is.
ASK
