Good Morning,
We are getting a solid-wood exterior door and we wanted to keep the grain exposed. I am leaning towards Waterlox Marine because I really like to use Waterlox. Any other suggestions? I never use poly, should I use it here?
Good Morning,
Hi,
Get ready to read a lot. The following information is from various posts I've saved on this very topic. Bleu
I wouldn't waste time with Thompson's. It's paraffin (wax) based - looks like it's doing a great job when you first put it on because the water really beads up. But what happens to wax in sunshine.......?
Sikkens is the best of the barrier coats. It is the Cetol System you want, and should be able to find it at good paint stores. In 35 years of professional door building, it is the only finish I recommend. Oil finishes will not last (more than a few weeks) if there is any ambient UV.
Sikkens Cetol is flexible and workable. When it fails (as all exterior wood finishes do) it merely looks dull and physically worn, and can then re-topcoated in a day. It does not crack or peel if applied correctly. Also good for both sides.
Post # 23121.1 at Knots
I found this article in about '98, lost it and just found it again. Some very interesting observations that I've never seen anywhere else:
In a recent post my friend, Steve, made reference to my tests of doggie sprinkling on exterior finishes. I figure after almost a year of testing it is time to post some interesting discoveries.
As a preface, allow me to set the stage. Almost daily there is a posting about clear, exterior finishes for doors, chairs, signs and such. Responses run the gamut from diehard marine finishes to apply a coat of primer and then paint. Each of these has a bit of a problem. Marine finishes are not always the easiest to find and it grieves me to think of a lovely oak, teak, mahogany, fir, redwood or similar nice wood door painted in mauve goop.
Bob from Fl inspired me with his continuing and accurate statements about the failings of a clear coat and the advantages of a good quality exterior paint. I decided after lots of reflection that he really was right but there was always the picture of mauve in my mind. Sooooooooo, how could one take advantage of his advice and yet capitalize on the beauty of a nice wood.
I began to reflect on the characteristics of paint. Now, comes the boredom.
There were several things I knew about paint. Exterior paints contain a mildewcide and a fungicide that a varnish does not. The best quality paints will contain a UV protectorant and trans-oxide pigments in very high percentages. Almost all paint is custom mixed by the store. The retailer maintains a large supply of base products that are used to achieve the desired color. There are generally 4 base products and the specific one for your paint is determined by your color choice. These base products are either named or numbered. They are named pastel, deep, tint and neutral. If numbered it is cleverly 1, 2, 3 and 4 with the exception of Olympic who numbers 1, 2, 3 and 5. Olympic is unaware that 4 comes before 5. Pastel and/or 1 is virtually a pure white and used for the lightest of colors. The others are slightly color altered from white and more translucent than pastel. These are used for succeedingly deeper colors. All of this comes to neutral, 4 and/or 5. These are clear and used for the darkest colors. In the can they are somewhat opaque but dry more or less clear.
Now comes the testing. I bought 4 oak exterior doors. Each door was given one coat of the same MinWax Stain. On 3 of the doors, I applied 2 coats of "base" to the 6 sides of each door (3 coats on the top and bottom edges). Each of these three doors had a different type of exterior neutral, 4 or 5 base. The fourth door was finished with a consumer "spar" varnish from my local friendly paint/hardware store. The bases for the 3 painted doors were an exterior semi-gloss acrylic, an exterior semi-gloss oilbased polyurethane floor paint and a semi-gloss oilbased trim and siding paint.
The doors were set up, slightly inclined, in mostly direct sunlight under a pecan tree in the backyard. My wife just loved that one. Daily, the sprinklers managed to hit the doors. The birds in the pecan tree used the doors for target practice. And, yes, the dogs did anoint the doors on a regular basis. My blonde Cocker, Zazu, was particularly enamored with the doors. Over the course of the test the doors experienced lots of Texas sunlight, rain and snow. The temperature went from below freezing to over 100. The advantage to the inclined position of the doors was the snow, ice, water from the sprinklers and the rain tended to collect in the raised panel areas. I feel these doors were subjected to far more severe environmental conditions than would be expected from normal use.
The results were interesting. The "spar" varnish looked fabulous but after about 2 weeks it began to develop small cracks. In rapid order the door began to turn black, started to mold and the smell was enough to knock a buzzard off of a manure wagon. The waterbased acrylic is milky in the can like a waterbased poly. It dried to a more or less water clear surface but was a bit cloudy. It tended to wash out the stain a bit. Over time it became cloudier and ultimately become almost white. But, it remained solid and protected the wood. The oil based bases are also a bit opaque in the can but dried to a clear finish that is almost identical to a spar varnish - they added an amber tone to the doors. Both the poly floor paint and the trim and siding paint remained "clear" over the entire test period.
The testing came to an end with a bit of encouragement. My wife said something clever like, "Get those damned doors out of the backyard?". She does not understand science. The floor poly had some minor checking and a thinned coat of the same base over the surface made that disappear. The door with the oilbased trim and siding paint was perfect other than it had lost a bit of the gloss.
So, I am with Bob - paint the door. My preference is the oilbased products. If you are predisposed to a waterbased use an acrylic rather than latex.
One thing you will find when you go out shopping for your product is a lack of knowledge on the part of the salesperson. Not many of these folk are aware that their neutral or 4 base will dry clear. If you want to have some fun, spring it on them. They will suggest you are full of Donkey Dust. Ask them to shake a can and put some on a stir stick. Dry it and voila, it is clear.
Jim Kull
Alan & Lynette Mikkelsen, Mountain View Farm, est. 1934, Gardens & Fine Woodworking, St. Ignatius, MT
And here was one more testimonial to the procedure....
My recollection is that Jim made this post back in July, 2002 (at least that is when I saved it on my computer). Prior to the complete explaination he would post bits of the same information. About a year and a month or two before this post (spring of '01) I was talking with Jim while driving to Virginia to assist my brother-in-law with some maintenance on their log home. One of the tasks on the schedule was to refinish their south facing, no overhang front door...again! It was at that time that Jim informed me of his "test". A couple of days later the door was stripped, sanded, and "painted" with Olympic brand exterior oil-based paint base #5. By my count that's coming up on five years.
Just before making this post I called my brother-in-law to see how the door is doing. The report is that the door looks as good as it did after we refinished it back in '01—it shows no
signs of cracking, yellowing, or any of the other common traits of Helmsman Spar Urethane in a similar high sun exposure; the builder recomended finish of choice before Jim's advice.
I have used a couple of other brands and find that all perform pretty much the same so long as you get the paint base used to mix the darkest colors. Testing, however, is always appropriate. I can also sympathize with lack of help you have
received from your local S&W dealer. As soon as you explain to the typical paint store employee what you intend to do the reaction is generally the same—"Oh, that won't work..." On one of my let's-have-some-fun-with-this-guy visits to a local Benjamin Moore dealer last summer I explained the concept to the salesman behind the counter. He assured me with great certainty that I was completely wrong (I getting accostum to
hearing that) and that what I proposed wouldn't work. I asked him to open a can of the appropriate base and just stick a wooden stir stick into the paint. When he withdrew the stick
he showed me with great pride how cloudy and milky it was. I told him to set it aside and I would return later. When I did his response changed; "OK, its clear; but, it still won't work—if you
don't add the pigment the paint won't stick right" (his words).
So, off to Lowe's with you, get the #5 base and have some fun...
Steve
And another
Polyurethane is one of the worst finishes for exterior work, worse even than Tung oil. It will fail - as do all exterior wood finishes - and will crack and peel when it does, necessitating a scrape and sand and chemical removal and total refinish of the door. I would try a test corner 3" square to see if the Cetol will adhere ok. I'd do mineral spirits woipe down first, perhaps with a fine 3m pad.
Use Sikkens Cetol 3 coat System for exterior doors and windows. It was developed for the very strong European door market, and designed for easy recoating. I tell my customers to use a .39 cent foam brush and recoat on a Saturday morning, and you can lock up at sundown.
Long story short, I'm a professional doormaker for 30 years. Along with that, I'm a door finish debunker also.
http://www.acornwoodworks.com go to the page on "Doors" Most of thses are Sikkens finishes.
There are more old drunkards than old doctors. Ben Franklin
Does your door get direct sunlight? If so that limits your choices. You might look at a good spar varnish like Epifanes. Take a look at boat supply places like West Marine. I used West Marines house brand of spar varinsh (sorry I don't have the can in front of me for the exact name) it was made by Epifanes and had a "fast" dry time of about 4 hours I still was able to only do one coat a day in the S.F bay area where I live. I have also heard good things about Cetol products as well. What ever you do try these products on a sample of the wood your using. Some of these products have a warm tint to them.
Troy
Anyone ever try making an exterior finish with boiled lineseed oil? Boiled linseed oil, mineral spirits, small amount of polyurethane varnish, M-1, and japan colors. Renewable, without building up a layer that will need to be scraped down the road.
>> Boiled linseed oil, mineral spirits, small amount of polyurethane varnish,Sounds like the exact formular for Watco Danish Oil which is a poor and short lived exterior finish.Howie.........
Please don't use clear polyurethane varnish on wood outdoors! It is short lived and the failure mode is most distressing.
What happens is the sunlight passes through the clear finish and destroys the bond between the varnish and the wood. Varnish with UV blockers only slows this down, when they are depleted this process occurs. The poly peels off in large flakes because the adhesion to the wood fails before the cohesion of the finish.
Acrylic or tung/phenolic varnishes (like Waterlox) are a much better bet. They are inherently resistant to UV damage, and stay flexible longer, so they can move with the wood.
Big overhangs are the best life extender for a clear-finished exterior door.
Bill
In my part of the world, central Texas, the biggest problems are sun and mildew. Mildew loves anything organic so I stay away from anything oil based. I have had the best luck with water based, UV stabalized products rated for outdoor use. At that I still need to refinish every couple years.
Any other suggestions? I would build something that keep the elements off of it. Like in a porch!
Thanks for all the information. This door will receive very little sun exposure as its under a deck walkway.
I am going to look into the higher end marine finishes, although Waterlox is expensive itself.
Now I'm toying with the idea building the door myself. I should know better by now.
The advantage of the top quality marine finishes is almost entirely its superior UV resistance. If your door gets little sun, I see no reason not to go with the Waterlox.
No date shown so not sure if I should comment. May be OLD.. I seem to find things that are so old the poster passed on....
I use to make custom doors for very old houses. Doors are not that easy to make but sometime in you life.. As a/an? old commercial said.. Try it! You'll Like It!
If it turns out good.. You will be HAPPY for many days! If not years.
