I am pondering the choices for an extieror door for our new house. I was considering using Mahogany and my supplier has three different kinds:
Genuine Mah $8.87 BF
African Mah $5.45 BF
Phillipine Mah $5.20 BF
It sounds like the various grade decrease in color richness from the Genuine to the Phollipine. Can anyone give recommendations as to the stability and suitability of each for an exterior door?
Also any other sugggestions for other suitable woods. By the way the door will be protected by a fairly large front porch and will be facing north here in Minnesota.
Aaron
It's my opinion that any one of them would be fine. The Genuine Mahogany typically comes from Central America or Mexico. That's the rain forest and there is not always a good political or ethical reason to be cutting them down. Hence, the supply may be less.
With your exposure, you should be fine with a proper seal. Keep in mind that the Mahogany is an open pore wood, so filling should be a must.
My own choice for an exterior door would be white oak. Although it is also an open pore wood, the pores are naturally filled with tyloses that make it naturally water resistant.
Terry
"Kinky for Gov. of Texas"
Terry,
You seem to have some experience with making exterior doors? can you tell me what is the prefered gap between the door and the jamb. I was think about 1/4". The door I am planning will be rail and stile with flat pannels. The rails will be about 5-1/2" wide and the construction will be in the early spring when humidity levels are relatively low. Any advise?
Aaron.
Aaron,
I don't know what weatherstripping issues you may have up there, but down in Texas the old-timers used to carry a silver dollar to use as their gap gauge for both sides and the top.
If you have the compression type of weatherstripping--similar to a refrigerator door gasket--the gap is not as critical. But aesthetically I believe I would still go for something around 1/8" gap.
Also, don't forget that the better you seal the wood, the longer you will enjoy it.
Terry
Thanks for the help. I will be using a rubber weather striping to seal the door.
Ipe is very beautiful and used for outdoor applications. Do a google search to see the color and grain pattern.
Douglas fir is widely used for making exterior doors, cypress is a good exterior wood but it is pretty soft for a door.
Jerry
