I just made some Adirondack chairs from some left over mahogany. Any ideas on finishes? Would like to stay away from varnish types and go more for the penetrating varieties. I would also like to go as maintained free as possible as the chairs are going to be a gift.
Bob
Oil is the way to go. Any film finish – such as spar varnish – will flake off unless you sand and recoat every year or two. Once a film finish starts to degrade,you will have to strip it off entirely.
Oil, on the other hand, can be reapplied after a quick rub down – mainly to remove any accumulated dirt. Be sure to use an oil that contains UV inhibitors. There are many on the market, but one I like that is commonly available (from HD) is called CLEAR WOOD FINISH from Minwax.
Here is a trick I learned from an old hand many years ago, and it works great. And that’s to make your own wiping varnish – by mixing spar vanish (25%) with an exterior oil (75%), and then thin the mixture with mineral spirits to the consistency of heavy cream (so it can be wiped easily).
The mixture builds quickly (2 or 3 coats is enough), and imparts a nice glow to the finish, which I like.
If the piece is exposed to all the elements (sun and rain), you will have to recoat every year or two. I have a set of stuff on my front porch, and I have to recoat about every 5-6 years.
The technique of making wiping varnish works equally well with interior products.
Good luck.
I found this reference on another board. As the poster said, if it does half what it promises it will be a great finish. I sent it to my son's FIL who has a log cabin in the Rockies and has to re-finish it every few years. He used to "refinish" by reapplying oil but has since been told that after the primary coat this should not be done.
http://www.onetimewood.com/
Edited 5/20/2004 7:32 am ET by GRETCHEN
Respectfully, the finish of your boats is not appropriate for outdoor furniture.
Varnish and Epoxy varnish coatings will wear on outside corners and provide a path under the film for moisture.
