Hey Knots,
Again I come for advice.
I’ve got some left-over sinker cypress 2x material that I’m using to make a new picnic table top for my back yard. It’s beautiful stuff and coming from sunken logs, I’m thinking it should wear well in the elements.
Would you suggest leaving it unfinished or do you think I should finish it with something? If I do put something on it, it needs to be non-toxic because my cats love to eat dry food right off the top of the table.
If you know sinker cypress, you know that it has a natural oily feel to it.
What do you folks think?
Ed.
The reason sinkers don't rot (or rot only very slowly) is that there's no oxygen in the water for the microbes. So the fact that a log lasted a long time on the bottom of the river doesn't necessarily mean it'll last a long time exposed to the weather.
I'd say leave it for a year. If you don't like the way it's weathering, you can sand or scrape it down to fresh wood again and finish it.
Hey Unc,
How stupid I feel. I never thought about the oxyen factor and the microbes. That makes enough sense to make me feel foolish.
I'll leave the top unfinished as suggested and see what happens.
Ed. Williams
There is no finish that last very well in outdoor conditions. If there was, us boaters would be all over it.
You need to make a choice. A penetrating finish will be easy to apply, easy to repair and re-apply from time to time. But, it may need to be maintained a couple of times a year. A film finish will initially last longer but still needs maintenence and is much more difficult to repair.
The better outdoor film finishes are the exterior marine varnishes made available at marine suppliers. Pettit, Woolsey, Interlux, Epifanes are some good ones. Follow the directions. Do not use a spar varnish. It is too soft to be durable. Use an exterior varnish.
Stay away from Big Box brands of "spar" varnish. Most are not very good. Also, an exterior vanish will be longer lasting that an exterior poly varnish. Poly does not take well to high levels of UV.
The best way to maintain outdoor furniture is to get some sun covers and then take it in during the winter.
Howdy,
Did you finish the picnic table or leave it natural? I am planning to build some outdoor furniture out of cypress and would like to know your experience on finishing it if any.
Ken
I've made close to a thousand picnic tables in my life and have tried many finishes. I only recommend a few things. 1-Leave it to weather. I've found the only place on the table that may rot is the legs because they touch the ground. 2-man o war makes a good product for this use. It's a poly of some sort that has pigment in it. It's a fairly hard film finish that holds up well-a few years. 3-Krylon had a pigmented poly they sold at walmart a few years ago that I had some luck with. Keep in mind the darker the color the hotter to the touch the table will be if it's in the sun. White is no good because the reflection of the sun will burn the retina's out of your head.
I've made some Adironadack chairs out of cypress and found only one product I'd use on them. It's Behr premium stain with silicone. It feels kind of slick for a couple months but does repel water. It's a pain to apply and lasts for a couple years.
Here are a bunch of posts from previous Knots that discussed this topic.
I wouldn't waste time with Thompson's. It's paraffin (wax) based - looks like it's doing a great job when you first put it on because the water really beads up. But what happens to wax in sunshine.......?
Sikkens is the best of the barrier coats. It is the Cetol System you want, and should be able to find it at good paint stores. In 35 years of professional door building, it is the only finish I recommend. Oil finishes will not last (more than a few weeks) if there is any ambient UV.
Sikkens Cetol is flexible and workable. When it fails (as all exterior wood finishes do) it merely looks dull and physically worn, and can then re-topcoated in a day. It does not crack or peel if applied correctly. Also good for both sides.
Post # 23121.1 at Knots
I found this article in about '98, lost it and just found it again. Some very interesting observations that I've never seen anywhere else:
In a recent post my friend, Steve, made reference to my tests of doggie sprinkling on exterior finishes. I figure after almost a year of testing it is time to post some interesting discoveries.
As a preface, allow me to set the stage. Almost daily there is a posting about clear, exterior finishes for doors, chairs, signs and such. Responses run the gamut from diehard marine finishes to apply a coat of primer and then paint. Each of these has a bit of a problem. Marine finishes are not always the easiest to find and it grieves me to think of a lovely oak, teak, mahogany, fir, redwood or similar nice wood door painted in mauve goop.
Bob from Fl inspired me with his continuing and accurate statements about the failings of a clear coat and the advantages of a good quality exterior paint. I decided after lots of reflection that he really was right but there was always the picture of mauve in my mind. Sooooooooo, how could one take advantage of his advice and yet capitalize on the beauty of a nice wood.
I began to reflect on the characteristics of paint. Now, comes the boredom.
There were several things I knew about paint. Exterior paints contain a mildewcide and a fungicide that a varnish does not. The best quality paints will contain a UV protectorant and trans-oxide pigments in very high percentages. Almost all paint is custom mixed by the store. The retailer maintains a large supply of base products that are used to achieve the desired color. There are generally 4 base products and the specific one for your paint is determined by your color choice. These base products are either named or numbered. They are named pastel, deep, tint and neutral. If numbered it is cleverly 1, 2, 3 and 4 with the exception of Olympic who numbers 1, 2, 3 and 5. Olympic is unaware that 4 comes before 5. Pastel and/or 1 is virtually a pure white and used for the lightest of colors. The others are slightly color altered from white and more translucent than pastel. These are used for succeedingly deeper colors. All of this comes to neutral, 4 and/or 5. These are clear and used for the darkest colors. In the can they are somewhat opaque but dry more or less clear.
Now comes the testing. I bought 4 oak exterior doors. Each door was given one coat of the same MinWax Stain. On 3 of the doors, I applied 2 coats of "base" to the 6 sides of each door (3 coats on the top and bottom edges). Each of these three doors had a different type of exterior neutral, 4 or 5 base. The fourth door was finished with a consumer "spar" varnish from my local friendly paint/hardware store. The bases for the 3 painted doors were an exterior semi-gloss acrylic, an exterior semi-gloss oilbased polyurethane floor paint and a semi-gloss oilbased trim and siding paint.
The doors were set up, slightly inclined, in mostly direct sunlight under a pecan tree in the backyard. My wife just loved that one. Daily, the sprinklers managed to hit the doors. The birds in the pecan tree used the doors for target practice. And, yes, the dogs did anoint the doors on a regular basis. My blonde Cocker, Zazu, was particularly enamored with the doors. Over the course of the test the doors experienced lots of <!----><!----><!---->Texas<!----><!----> sunlight, rain and snow. The temperature went from below freezing to over 100. The advantage to the inclined position of the doors was the snow, ice, water from the sprinklers and the rain tended to collect in the raised panel areas. I feel these doors were subjected to far more severe environmental conditions than would be expected from normal use.
The results were interesting. The "spar" varnish looked fabulous but after about 2 weeks it began to develop small cracks. In rapid order the door began to turn black, started to mold and the smell was enough to knock a buzzard off of a manure wagon. The waterbased acrylic is milky in the can like a waterbased poly. It dried to a more or less water clear surface but was a bit cloudy. It tended to wash out the stain a bit. Over time it became cloudier and ultimately become almost white. But, it remained solid and protected the wood. The oil based bases are also a bit opaque in the can but dried to a clear finish that is almost identical to a spar varnish - they added an amber tone to the doors. Both the poly floor paint and the trim and siding paint remained "clear" over the entire test period.
The testing came to an end with a bit of encouragement. My wife said something clever like, "Get those damned doors out of the backyard?". She does not understand science. The floor poly had some minor checking and a thinned coat of the same base over the surface made that disappear. The door with the oilbased trim and siding paint was perfect other than it had lost a bit of the gloss.
So, I am with Bob - paint the door. My preference is the oilbased products. If you are predisposed to a waterbased use an acrylic rather than latex.
One thing you will find when you go out shopping for your product is a lack of knowledge on the part of the salesperson. Not many of these folk are aware that their neutral or 4 base will dry clear. If you want to have some fun, spring it on them. They will suggest you are full of Donkey Dust. Ask them to shake a can and put some on a stir stick. Dry it and voila, it is clear.
Jim Kull
Alan & Lynette Mikkelsen, Mountain View Farm, est. 1934, Gardens & Fine Woodworking, St. Ignatius, MT
And here was one more testimonial to the procedure....
My recollection is that Jim made this post back in July, 2002 (at least that is when I saved it on my computer). Prior to the complete explaination he would post bits of the same information. About a year and a month or two before this post (spring of '01) I was talking with Jim while driving to <!----><!---->Virginia<!----><!----> to assist my brother-in-law with some maintenance on their log home. One of the tasks on the schedule was to refinish their south facing, no overhang front door...again! It was at that time that Jim informed me of his "test". A couple of days later the door was stripped, sanded, and "painted" with Olympic brand exterior oil-based paint base #5. By my count that's coming up on five years.
Just before making this post I called my brother-in-law to see how the door is doing. The report is that the door looks as good as it did after we refinished it back in '01—it shows no
signs of cracking, yellowing, or any of the other common traits of Helmsman Spar Urethane in a similar high sun exposure; the builder recomended finish of choice before Jim's advice.
I have used a couple of other brands and find that all perform pretty much the same so long as you get the paint base used to mix the darkest colors. Testing, however, is always appropriate. I can also sympathize with lack of help you have
received from your local S&W dealer. As soon as you explain to the typical paint store employee what you intend to do the reaction is generally the same—"Oh, that won't work..." On one of my let's-have-some-fun-with-this-guy visits to a local Benjamin Moore dealer last summer I explained the concept to the salesman behind the counter. He assured me with great certainty that I was completely wrong (I getting accostum to
hearing that) and that what I proposed wouldn't work. I asked him to open a can of the appropriate base and just stick a wooden stir stick into the paint. When he withdrew the stick
he showed me with great pride how cloudy and milky it was. I told him to set it aside and I would return later. When I did his response changed; "OK, its clear; but, it still won't work—if you
don't add the pigment the paint won't stick right" (his words).
So, off to Lowe's with you, get the #5 base and have some fun...
Steve
Alan & Lynette Mikkelsen, Mountain View Farm, est. 1934, Gardens & Fine Woodworking, St. Ignatius, MT<!----><!---->
And another<!----><!---->
Polyurethane is one of the worst finishes for exterior work, worse even than Tung oil. It will fail - as do all exterior wood finishes - and will crack and peel when it does, necessitating a scrape and sand and chemical removal and total refinish of the door. I would try a test corner 3" square to see if the Cetol will adhere ok. I'd do mineral spirits woipe down first, perhaps with a fine 3m pad.
Use Sikkens Cetol 3 coat System for exterior doors and windows. It was developed for the very strong European door market, and designed for easy recoating. I tell my customers to use a .39 cent foam brush and recoat on a Saturday morning, and you can lock up at sundown.
Long story short, I'm a professional doormaker for 30 years. Along with that, I'm a door finish debunker also.
http://www.acornwoodworks.com go to the page on "Doors" Most of thses are Sikkens finishes.
There are more old drunkards than old doctors. Ben Franklin
Thanks for the effort on the reply, very thorough.
I'll leave it unfinished based on your experience.
Ken
You're welcome. Just remember to try to keep it off the ground if you can. In my experience the legs always rot where they contact the ground. I've made many picnic tables from eastern white pine that have lasted for 15 years left outside year round.There are more old drunkards than old doctors. Ben Franklin
