Just received my EZ square and it is everything Dino promised it would be. Just slide the mounting brackets (same as connectors) into the back of the rail, hand tighten two screws, and you are ready to start cutting. The mounting system takes advantage of the self-aligning dove tail system so no adjustments are necessary. The cut-out style handle proved to work great – it made moving the square easy. It was dead on.
To make things even better, I added a 26″ repeater (Install 2 studs in predrilled holes and put the repeater on it). The repeater functions as a fence for cuts up to 26″ wide. Using the combo, I was able to quickly and precisely make multiple cuts of the same width.
Here is a link to some photo’s of the repeater/square combo: http://eurekazone.com/gallery/ez
From my experience, EZ Smart has another real winner on its hands
UPS shows my square and repeaters arriving tomorrow.
Next time Dino pops out of that bottle, I'm wishing for a miter gauge and a new 1 ton work truck that gets 50 miles to the gallon!
Let's hope the cork isn't too tight!!
