I am building a TV cabinet from birch ply with a poplar face frame. Would it be strong enough to just glue the face frame to the carcass? Do I need to use biscuits?
Scott
Scott
Glue will be fine as long as you have a properly fitting glue joint, Biscuits are really for alignment ease and don't at that much in structural support,
Thanks for the help.
If you are going to just glue, I'd wager that a "properly fitting glue joint" equates to rabbeting the back of the frame to fit the carcass panels. I prefer nails for purely from the simplicity standpoint, but often the aesthetics of the thing don't really allow for that. I've used biscuits, not a big fan there, and splines, a little better. If it's going to be a built in with the outsides not showing, pocket screws are an option as well. You can do the same thing on a visible piece with an extra side piece, which helps the reveal on carcass-work like bookshelves so one end of your frame doesn't overlap the shelf more than all the center partitions.
" To the noble mind / Rich gifts wax poor when givers prove unkind" - Wm Shakespeare, Hamlet, III,i,100
