HI MATT,
QUESTION ON 3/4″ THICK WHITE BIRCH FACE FRAME GLUED AND DOWELLED.
DESIGN CALLS FOR A 10″ HIGH BASE TOE ON BAR FRONT. IT WOULD BE GLUED AND DOWELLED TO THE CORNER VERTICAL STILES. STILES ARE 1-1/2″ WIDE.
THE GRAIN RUNS HORIZONTAL ON THE 10″ PC. DO YOU THINK THE 10″ PC.
WILL EXPAND AND SPLIT AT THE DOWEL JOINT?
SEALED WITH STAIN AND CONVERSION VARNISH.
THANKS FOR YOUR HELP
JEFF
Jeff,
A rule of thumb is that wood can expand around 1/16" per foot of width. So you're talking less than 1/16, depending on your humidity, etc. So it might not be a problem for just 10". But if I were doing it, I'd use Birch ply for the toe kick and join it to the stiles (verticals) with dowels, or pocket screws.
Tom O'Brien, All Quality Woodworking
Scotts Valley, CA
I agree with Tom's advice. However, even if you do go with solid wood I don't see movement being an issue.
Matt Berger
Fine Woodworking
